Excessive smoke comes out from my oven when heating up for instance a loaf of bread.
I have a self cleaning oven and did the self cleaning twice. It is very clean but each time I try to cook and open the door excessive smoke comes out. So much so that all my fire alarms went off.
Help..
Lisa
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked. the switched is located next to the hook that locks your door.
SOURCE: oven smoking
I am pretty sure this is just the steam escaping. Smeg ovens seal so evenly that the steam stays in the oven.
SOURCE: "Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
smoke is caused only by fat getting onto an element and should stop after a while, ie when all the fat is burnt off. this is usually a problem with the grill element.
you can get a finjhe mesh grid which fits over the centre vent in the back plate and this should help
SOURCE: "door lock" light stays on and oven won't work
Same problems. When I removed the lock operating arm nothing happened. Motor is not operating. I've temporarily kluged it by tying the "unlock" (upper) switch circuit together and disconnecting one side of the power to the "locked" (lower) switch. At least we'll have an oven to use, but I'll have to come back and remove the lock motor assembly to find out what's really wrong.
BTW, if some knows those keyed-in service codes they could be useful.
