Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on May 02, 2010
Adjusting brake on Craftsman LT 1000 lawn tractor manual
How to adjust brake on LT 1000 craftsman lawn tractor
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Jul 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
13709
Points
34
Underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor · Operation Manual.Craftsman Lawn Mower manuals - ‎Craftsman 247.370310 - ‎Craftsman 247.37030
Brake adjust need manual craftsman lawn tractor 917 257 620 manual
The manual for your mower is here: (5.08 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/LR707473.pdf
Brake adjustment is on the bottom left of page 20.
Thanks for choosing FixYa,
Kelly
A cable is loose that will not allow me to engage the blades, how do I reattach the cable. it is a craftsman Lt 1000 17 IC ohv . model # 917.272260 42 inch cut.
Tightening up a stretched cable is impossible. If the cable is NOT adjustable to shorten it and make it tighter, then you will need a new one. Here is a link to one. I searched all the parts diagrams in your manual for the cable and find it was NOT listed. I hope this helps as I have researched your problem. Go here:
http://amcpartsstore.com/FSP-Deck-Blade-Engage-Cable-Craftsman/M/B0014G6T1S.htm
5helpful
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Craftsman 26HP Lawn Tractor Parking Brake
There is not an adjustment on the parking brake. The problem you are having may be caused by the drive belt stretching.
8helpful
1helpful
13helpful
Need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
2004 y2000 6 speed manual, and the brakes are
look on the side of trans you will see a small
disc that is your brake there should be a 10mm or 3/8 nut there tighten this nut your brakes should come back.
Craftsman riding mower lt 1000 deck jumps out
First I'd try lubricating the relevant moving parts. Spray with WD-40 everywher that makes sense.
If that doesn't help it work better, please, get bck to me.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
