SOURCE: Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
bd.
SOURCE: problem importing files to Tascam DP02-cf
They don't mention in the manual that in addition to being 44.4khz, 16bit, mono, the wav file also has to be at a bit rate of 705kbps. Using Audacity (freeware) you can convert most any audio file into the necessary wav format for the DP-02cf to use.
SOURCE: transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
SOURCE: I've been exporting master tracks and now I've
If you NO LONGER NEED the songs/data in the FAT partition, you can delete the entire contents thereof in the manner detailed below. Note that these instructions were taken directly from the Neo manual.
1 With the transport stopped, from the DISK menu, highlight FAT REFORM, and press YES/ENTER.
2 A pop-up message appears.
3 Ask yourself once more if you want to erase all the data on the FAT partition. Press YES/ENTER to continue with the operation when a pop-up appears, or press NO/EXIT to halt the operation.
4 When you reformat the FAT partition, four directories (folders) named WAVE, SMF, BACKUP and UTILITY are automatically created. These folders are used for audio files, Standard MIDI Files (SMF) and backup data and system utilities, respectively.
...this will reformat and thereby EMPTY the contents of the FAT partition and create the 4 new, empty files as listed above.
THINK before you do this though, and I hope this helps.
i have a tascam dp-02(not the cf)and what i've found is once you master AND save a song press 'menu', scroll up to 'disk', press 'FAT reformat, press 'yes'press'wave', press 'export master', press yes, be patient ... this'll take a minute depending on how long your song is, once that's done press 'USB' , it'll ask you if your sure, press 'yes' and you should see it as an external drive on your PC ... open the 'WAVE' folder and fom there you should be able to save the song to your hard drive ... the only issue i have is that it's exported as a WAVE file ... you might wanna look into a converter that'll compress it to an mp3 file.
