Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
This watch is self winding and will stop after 2-3 days if not worn.
To wind it up,shake it from side to side gently for a few minutes (about 100-200 times) and this should wind it up sufficient to make it run for some time.
These watches thrive on being used and if you wish to maintain its operation, wear it at least every other day.
Your watch is an automatic type which means that it is a mechanical self winding watch powered by a spring. It is wound up by a weight that moves when you are walking about and this watch must be worn to keep it operating.
If not worn, these watches will stop in 2 -3 days because the spring has run down.
Some automatic watches can be wound using the crown wheel (winder) but if yours cannot be wound in this way, then swing it from side to side gently for a few minutes and the watch will wind up.
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
If the watch has been allowed to run down, then it may need some considerable activity to wind it up again.
Hold the watch level and shake it gently from side to side for a few minutes (this should operate the self winding mechanism and wind the watch up). After this, wearing the watch should keep it wound up.
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
