Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
Posted on Apr 18, 2010
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
How do you fix a battery that has gone flat as it was left in a tool to long with out a charge now when you put them on the charger it comes up with fix and repair but dosent move on from there. Thanks Davie
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Oct 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
38788
Points
14
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
  • Anonymous Sep 12, 2012
    Which charger works with the "defective" batteries? Thanks!
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
36484
Points
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
  • Anonymous Jun 28, 2013
    I don't think so. You're the one who replaced Konion cells with Ultrafire junk.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5852
Points
Can you get makita lithium batteries repaired ive got 5 nd 3 have stopped working they re only just over 0ne year old?
Can you fix a lithium battery?
The Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 us the BL1830 battery, there are several types for it, 1.5Ah, 3.0Ah, 4.0 Ah. Maybe 5.0Ah battery for it will be available. And, the inside of the BL1830 uses the 18650 battery cell. If you have a good knowledge and skill about electronic, you can buy some 18650 cell to do it yourself. If not, I suggest you to buy a brand new one.
You can buy some original battery for replacement battery for Makita BTD140 Battery
2answers
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
Dewalt lithium battery won't charge
Your problem states you have a Makita tool and your question is about a Dewalt lithium battery. In either case if the battery won't take a charge or if the charger is showing the battery is defective the only fix is to replace the battery. Some causes for defective batteries or batteries that won't take a charge are bad cells in the battery, bad or shorted IC board in hte battery, broken or burnt connections between the many cells or between the cells and IC board or even bad or old cells that will no longer charge up. The time and effort needed to find out what the problem is then finding another battery to scavenge parts from (individual battery parts are not available) is never worth the cost of just buying another battery and going back to work with the tool(s).
2helpful
2answers
One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
I have 2 batteries that will not charge. They are 18v lithium batteries. The charger just flashes red and green
I do not about a Makita, but my experience with other brands is when that happens, it means the battery is no good and needs replacing.
I have a li-ion Makita BL1830 18V 3.0Ah battery that can't be charged...when on the charger the bottom two lights flash red..it will charge my other battery, so it doesn't seem to be the charger
Sorry Mate your battery is dead...
The makita lithium batterys dont like getting worked hard quickly.
There is a chip in them that recognice each battery to each specific charger. Try another charger. This has not worked for me. Try anyway
2helpful
2answers
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
