I have got a nokia 6300 which has been damaged by water,which stopped working but after i kept it under a towel on the radiator it started to work as new in fact it was working perfectly as if it hadnt ever been in water but then a few weeks later the backlight just stopped working suddenly,the keypad lights up though what should i do?
Unscrew the phone, Get a Methylated spirit and a brush, Bring out the board of the phone and use the methylated spirit to brush off remaining water on phone. Keep under heat to dry off, After board is dried, fix it back and screw back phone.
Am sure after doing this phone will work well. But if phone still doesn't work ,that means water has damage some component inside the phone. You will need to consult a phone technician for assistance. Take care.
hi :)
back light no working,maybe is display spoil already.
your phone have water damage ??
maybe the light ic was spoil.
u may send for technician for repair.
i have heard that the 6300 has a gneric problem of the speakers not working even with the slightest of water entering it...you can get this done under warrenty if you just baught it.
or it might be as simple as youe volume is muted or the phone is in slent mode.
open the Hand SET THEN GET a Normal Brush And A Nail Polish Thinner or spirit the celean the board IF not Work THEN IT Means UR KEYPAD IC is not working properly if Solved THEn plS rate me
Unfortunately no....depending on the water damage that had occured. It would have been quite lucky if the phone actually worked. and if it did, other aspcts of the device may work now but fail later. No one part can be identified for repair because water can get into EVERY component. Making repar an expensive option. Replacement is the only recommendation
