GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Mar 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power cuts out after about 5 seconds
Any power or timed setting, turn on, runs about 5 secs and shuts off completely including the clock. Message says "power went off during cooking" but it did not. Note there are light flickers in the display as the timer counts down. Will not restore until clock is reset. Then it happens all over again.
  • 3 more comments
  • Anonymous Mar 19, 2008
    My microwave started a couple of day ago to garble the display and tell you to set the clock after coming on 1 or 2 seconds. Help will be appreciated. Manufactured date Feb. 2005
  • Moseby76 Mar 19, 2008
    What is a "form main?" I unplugged it from the wall.
  • Moseby76 Mar 24, 2008
    No Joy.
    What is a "mains"?
  • Anonymous Jul 23, 2013
    Hi... have a 2.5 year old GE JVM1850DM4CC and had the same issue. Tried unplugging and did not help. Tried resetting the main breaker, did not help. Is there an internal fuse or something cheap and easy to try and replace? Thank you.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
824
Points
0
I unplugged the power for about 8 hours. I work 3rd shift so I unplugged it while I was getting my nights sleep during the day. Tried setting the clock and heat a cup of water. It ran 2 seconds and then the display went to all characters and finally back to please press the clock button, just as it did before. Other functions like the timer will work fine and the clock stays online until the microwave is set to heat. Any other possible solutions?
Barry
Anonymous
Level 3:
  • Master 4,102 Answers
  • Posted on Mar 19, 2008
Anonymous
Master
Level 3:
Answers
4102
Questions
26
Helped
1200606
Points
14563
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
  • Anonymous Mar 23, 2008
    hi sorry but been offline due to illness it should have said unplug from mains doing this will reset the microwave hopefully solving your problem please let me know if not then i can assist you further ok
I cannot get the GE microwave clock to set! Help?
To set the clock on most GE microwaves:
1 With the microwave door closed, press CLOCK.
2 Touch number pads that reflect the time of day (1:45 would be 1, 4, 5).
3 On some newer models, indicate AM or PM for morning or evening.
4 Press CLOCK or START to lock in the time.
If you prefer not to display the time:
Disconnect the power for 30 seconds. After restoring power, do not set the clock. If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
1helpful
The oven hums and then shuts off within about 5 to 10 seconds of being started no matter what power level or time is set. The "keep warm" setting will run for the amount of time set but the food...
hi there
unfortunately your magnetron has failed and the thermal cut-out located on the top of it is cutting in to prevent overheating and possible fire risk.
regards
ian
1helpful
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
2answers
I have a Maytag Model MMV5207BAB over the range microwave oven that crapped out after 11 mos use. No warning, just no power. The outlet is fine I have no power surge problems in my house. This is the...
There is an internal fuse which is located underneath the side\top shell. If you have no lights or control panel, this is the most likely cause. This is not difficult to replace.
1helpful
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
1helpful
3answers
Microwave shuts off after 2-5seconds
The problem is most likely the magtube, it takes aprox 3 sec for the tube to energize and then it kills the microwave. If you drop the control panel away and start the microwave 90% of the time it will cook fine.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
