My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
If you try to wind the bobbin with the embroidery unit on, you need to send a design to the machine before trying to wind the bobbin. If the embroidery unit is off, you should wind the bobbins without any problems
If you are winding the bobbin in the middle of sewing process, it is normal to get a notification (E5) that bobbin winder should be returned to the left position before continuing to embroider.
When you engage the bobbin winder it has a small rubber in which it makes contact with the driver rubber maybe that is not making contact, to stop the cotton from showing on the top, adjust the small screw on the bobbin holder tighter clockwise.
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
