Konica Minolta magicolor 2430 DL Laser Printer Logo
Alan Morrison Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Poor print quality
I get a ghost image repeating about 6 inches below the original image print. This happens on a black print. Color is also uneven. I put a new black toner cartrige in (even though it said 65% remained).
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Apr 07, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557759
Points
31058
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Print problem sir in 2420L
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing.
Happy with us Dial Epson Printer tech support phone number 1-877-778-896 for technical support of customer executive regarding with the Epson printer, if your printer is not connected with your PC & Laptops, Don't worry, dial our Tollfree 1-877-778-8.9.6.9 and get better and feasible solution of your issues within a time in the USA.If you want more information regarding with Epson n printer visit us:http://printertechnicalhelp.com/epson-printer-technicalhelp.html
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
2answers
Canon ip4850 print quality
Whats the question?? if poor quality printing, it could be dirty ink cartridges, dirt on the print head, poor quality paper ??? try looking at the printer settings, sometimes they may be set to economy rather than top quality printing.
I'm not quite satisfied with color and black tone. What settings would you recommend.
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
1helpful
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
2600n faded print on both left and right side.(word doc, no images) not using color black print only.
Is the cartridge an original HP or an inexpensive compatible? The black cartridge could be out of toner. Not a common defect for the Q6000A cartridge though. If it is a poor quality compatible the defect may be the result of a misaligned internal component. Either way replacing the black cartridge should resolve the issue.
2helpful
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
2answers
Poor quality black output
There is a defect in the Imaging Unit of these printers....if you replace the imaging unit, the problem of the faded black prints go away. If you have less than 7000 prints, you can call Samsung for a warrantied replacement. The Imaging Unit is supposed to last at least 20,000 prints.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
