Teac Reference DR-H300 Logo
Posted on Apr 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My TEAC DR-H300 HDMI is reading discs intermitently, i.e. sometimes it does, most times it doesn't. Once I insert the disc and close the tray it stays with the message LOAD and nothing else happens. Could it be that it needs to be re-booted?
woozie38
Level 3:
  • Master 608 Answers
  • Posted on Apr 06, 2010
woozie38
Master
Level 3:
Answers
608
Questions
Helped
229080
Points
1829
The usual cause of this is the optical disk itself. Either the media has defects that your player doesn't like, or the codec needed to 'read' the disk is missing or unknown. Try playing a standard DVD from the music store. If that plays ok, you may need to upgrade your firmware. New firmware should be available from the maker's web site.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
761
Points
I have a similar problem unrelated to the disc... my unit gave up reading dvds entirely after 2 years, and was reading cds sporadically, I had the cd/dvd mechanism replaced, and the replaced unit gave out after about 6 months, with the exact same problem.
My Teac MD-H300 minidisc player will not read discs, comes up no disc
Doe the deck play LP discs or only SP discs?
My impression is that it does not support MDLP - which I suspect is your problem.
Does it play discs recorded on that machine?
Let me know if that solves it. If not, I have other thoughts.
I have a teac MD-H300 minidisc player that doesn't read discs
That's an old machine from 2001. Buy a working machine on eBay or Craigslist.
Teac md-h300
There is no unit with the name you gave.
Does the unit itself say MDLP on it? If it doesn't, theres a good chance it doesn't support the LP modes and will only playback/recor unit only plays in SP or MONO.
1helpful
My Teac DR-H300 will not open the dvd drawer anymore. It looks like the magnet won't release on the drawer. Can anyone tip me what to do?
I solved this by holding the power button down for 5-10 seconds. After a reset the drawer opened as normal.
4helpful
Xbox 360 says reading then open tray, close tray
check the unit with a different disc, also better do a optical disc cleaning on yur unit. sometime lens get dirt and hard to read the disc inserted.
hope this helps
Cannor Read DVDs
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
2answers
TEAC DH 300 can't get HDMI to work, something to do with " all" settings.
I have the same problem. I have connected it to Philips TV, but there is no signal. I cannot even enter setup on Teac. The SETUP button is not simply working. Can anybody help? Please!
2answers
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
2helpful
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
