SOURCE: black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
SOURCE: Bottom half of the screen goes black
Make sure you have the text turned to off in the closed caption settings
SOURCE: BOTTOM HALF OF SCREEN GOES BLACK R A MINUTE OR SO
remove the back of the tv.disconnect and reconnect the ribbon cables into your buffer pcb.if this does not correct the problem replace the buffer pcb in that location where the screen is going black.you also could have
a defective panel if the buffer pcb does not correct your problem.
SOURCE: Bottom half of the screen goes black frequently.
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Print out the readme file the delete it off the USB Flash Drive
Make sure the USB Flash Drive has only one file on it (autorun.upg)
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
SOURCE: my plasma, bottom half of the screen is black
Hi, It is your lower Y sus Buffer. Runs about $80
BN96-03362A Y main buffer lower.BN96-03361A Y main buffer upper. Encompasparts.com Also try Shop Jimmy, And Ebay. Sometimes they are lower in price.
