SOURCE: mabis mist II not making mist
have you checked the wall plug to which you have tried to plug it in or maybe the cord to your nebulizer has a short in it somewhere and last maybe you need a newer model. Good Luck!
SOURCE: Omron nebulizer will not mist. All tubing is intact. What to do?
I would assume there is a problem in the filter or nebulizer/medicine cup area but your best bet would be to contact Omron technical support at 1-800-634-4350. Since this unit has a five year warranty i would stick with dealing with Omron. Good luck and please rate solution.
SOURCE: my nebulizer has air coming out but no mist
The tube from the medicine is probably blocked. Generally needs factory service.
SOURCE: no medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
I, too, am looking for a manual for this product. I get a green light, but it does not appear to have any airflow coming from it.
