Canon XM1 Mini DV Digital Camcorder Logo
Posted on Mar 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My heads on the xm1 seem to be dirty, ive used a sony cleaning tape, it only makes a difference for an hr or two taping, any sugestions
Anonymous
Level 3:
President:
  • Master 720 Answers
  • Posted on Nov 05, 2011
Anonymous
Master
Level 3:
President:
Answers
720
Questions
0
Helped
438458
Points
2330
Firstly, I must explain how the MiniDV system works:
Although this may sound illogical, MiniDV camcorder heads do actually use a type of lubrication cassette system and there are 2 types:
- DRY lubrication (Canon, Panasonic, JVC etc)
- WET lubrication (Sony)
Now, if you haven't noticed already from the above 2 types, you are in fact using the WRONG type of cassette on your camcorder.
Although Sony cassettes are often readily available (and often perceived to be the best quality), by using Sony cassettes on a Canon camcorder (or Pana, JVC for that matter), you are in fact causing premature wear on the heads. So, the condition you are describing as 'dirty' heads, is in fact caused by the use of the wrong (wet type) cassettes on your DRY type camcorder.
Using "WET" type cassettes on a DRY system camcorder, can often leave residue on your heads, or worse....cause wear. The same principle applies to Sony camcorders - use only Sony 'WET' type cassettes, not Dry cassettes.
This also applies when using HEAD CLEANER cassettes - as indicated, you have used a Sony Head Cleaner cassette (this is a WET type cassette), when in fact, you should be using a DRY HEAD CLEANER cassette (Pana, Canon etc).
CAUTION: when using a head cleaner cassette, only playback the cassette for no more than 6 sec's at a time (anymore will damage the heads).
Summary:
For your Canon camcorder, use only DRY MiniDV cassettes (Pana offer cassettes from Studio, Professional to Master Quality), including DRY Head Cleaner cassette. This should improve the playback quality from your camcorder.
Jvc vcr manual
It's probably the tape head is dirty. Try cleaning it first before playing your tape. Use clean cloth with a head cleaner solution (lighter fuid or 70% isoprophyl acohol will do). Or check your connectors, usually the yellow one (if RCA connectors) is for the video, the white or black for the left, red for right jack.
4answers
JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
try to do a player head cleaning. just be careful doing this..
thanks
The tape is running but not showing a picture on playback
probably your drum head is dirty and need to be clean
you can use a tape head cleanner but i dont garantie the result
best is a manual cleaning made by a technician /but sometime its works with the tape head cleaner if its not to dirty and sugest you trow away the cassette you have to use all the time
hope that will help
regards Alan
2helpful
Hello, when I shoot lately with my canon xl1 the first few minutes of the tape only records black or you can see some of the video as horizontal bars. it is only on the first few minutes of a tape. The...
well ,,,,you got a dirty tape head,,,try running a head cleaning tape through the camcorder to clean it out,,
have you been using old tapes???
that would get the record head dirty prity quick,,,
also if the camcorder was a little damp it takes its time to warm up first,,,
i hope i have given you some idears to work on
Sony handy cam
If your Sony tells you it is recording yet on playback there is nothing there other than a blank screen, I had this problem and this is how I solved it.
1. Clean the heads two or three times with head cleaning kit
2. Leave the tape door open, with tape out or in, and warm the camera up for about 2 hours minimum.
3. Put in a previously recorded tape and see if it will display that film. If not, repeat 1 and 2. Persevere.
4. Once Stage 3 works (you might have a few "dirty" lines on it for a few seconds, and it is playing normally, try recording.
This worked for me. The heads were dirty and the camera cold but I persevered and thankfully it is OK (but for how long?)
Hope this helps. It seems to be rooted around dirty heads and coldness.
Problems viewing Hi8 tapes
Seems video head of your handy-cam is dirty or clogged. Use good quality video head cleaning tape to clean video head.
I have an old Sony Hi8 Handycam model CCD-TR705E. Have not used it for about 4 years and decided to upload tapes to DVD via a DVD recorder. Worked fine for the first 5 hours of film then suddenly picture...
Try to use video head cleaning cassette one more time and check. Problem still exist then....
There is a very special cassette used to clean much dirty video heads calls Lapping Tape.
This is provided only to Sony Service Centers.
You need to contact nearest Sony Service Center.
Oct 06, 2008 • Cameras
Reinsert casette tape
I suggest to clean tape head directly w/ QTIPS and the solution to clean video heads , clean and try again , thanks AJ
D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
