Watches Logo
Anonymous Posted on Mar 25, 2010
How do i get hands on my swiss legend chronograph to reset to proper position when changing battery?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
279
Points
F16185 i want a belt in brown colour
Reset chronograph hands on Accurist 7344
To reset the chronograph hands on an Accurist 7344 watch, you will need to follow these steps:
  1. Pull out the crown to the second click (time-setting position)
  2. Press and hold the top button (located at 2 o'clock) until the chronograph seconds hand returns to the 12 o'clock position.
  3. Release the button and then press and hold the bottom button (located at 4 o'clock) until the chronograph minutes hand returns to the 12 o'clock position.
  4. Release the button and push the crown back in to the normal position.
It's important to note that these steps may vary depending on the specific model of your Accurist 7344 watch. If these steps don't work, refer to the manual or contact the manufacturer for more detailed instructions. Additionally, if the chronograph hands don't move at all, check the battery and make sure it's properly inserted and the watch is working properly after replacing it, if not, contact Accurist customer service for more assistance.
Jan 14, 2023 • The Watches
Swiss Legend 10542-05-BB Men's Trimix Diver Chronograph Watch Red what number of battery do I need?
You are wanting to know battery type, not number. Take your Swiss Legend watch to a jeweler who will show you the correct way to open it and replace the battery.
What is battery model# for a swiss Legend Commander Chronograph watch?
Here is a number to find out:
Swiss Legend Watches
"Express Your Time"
3701 S. Flamingo Road, Suite 100, Miramar, FL 33027
Toll Free
: 1-866-746-7794
Battery for swiss legend maverick
Any jeweler can provide the correct batter.
1helpful
Replace links on Swiss legend ceramic watch
here is a video that will show you how to remove links on your ceramic watch band
2helpful
How do I set the day of the week dial on my Swiss Legend Chronograph?
If the day will not change when you pull the crown out to the first position (try both directions) then pull the crown out to the second position. Advance the hands until yesterday shows in the day window. Now set the date by putting the crown in the first position and set it to yesterdays date. Now advance the hands (position 2 until the date and day change and then set the time. Done
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
11helpful
The second hand on my chronograph will not index properly when reset
Try this or some variation as it worked with my new Wenger Chronograph.
Pull the crown out to the first position (for changing the date) and press the top button - one of the hands - either the big second hand, the little minute hand, or the little tenth of seconds hand - should move one notch. Keep pressing until it reaches the desired position. Now press the bottom button, same process. Pull the crown all the way out and press the top button, same process. Then if that still hasn't solved it, crown all the way out and press the bottom button. Each position should correspond to a hand, and each press should move it one notch. When settled, push the crown all the way in and operate it normally.
Be careful not to press buttons when changing the date or time, and don't bang or shake the watch too hard while using the chrono. Also, don't play with the buttons or press them one after the other too quickly.
Swiss g10-211 movement doesnt keep time runs when it wants to
This movement wasn't meant to be repaired, so replacement is your only option. These pop up new on eBay from time to time for around $30 shipped. Make sure you get one with the date in the correct orientation/position (e.g. date at 3 o'clock or date at 4 o'clock). Best to enlist the services of a watchmaker if you haven't removed and replaced hands on a watch before (particularly a chronograph).
2answers
How to change the battery in a Fossil watch
The back twists off. Just make sure that when you put it back together that the o-ring is seated properly.
Apr 03, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
