The TX-DS595 receveiver won't respond to remote(s). Remotes are OK. One is the orig remote and the other remote is a learning remote. I've replaced batteries in remotes and have disconnected power from receiver for about 5 minutes. Receiver works ok when using the controls on the front of the unit. Unit is about 9 years old. Have not had any problems with it before.
When unit is on hold down vcr button and press standy power button. display will read 'CLEAR". turn back on and see if remote works. note that this will erase any of your settings. Point the remote at any camera and look at the camera display. If you see a white light when you press buttos remote is working. Remove the top cover, remove front cover and resolder connections on remote receiver. If you intend to do this let me know and I can give you more details.
I am having this same problem with my Onkyo TX-DS595. Could I ask did you solve the problem and how did you do it?
just wondering if anyone solved this? I'm having the same issues with my Onkyo TX-DS 595. The remote is fine because I bought an original tested one and same results. I'm wondering if the IR extender on the back of the receiver could be a work around or does the IR sensor in the unit have to be in good working order?
