I have a Hitachi 60v500a. the lamp blew i replaced it and still no picture. when i turn it on i get the blue and two red lights then only the lamp light stays on and no picture or sound.
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
the TV was working then i heard a pop i knew it was the bulb because it happened 2yrs ago i will look at the door. but if it isn't that then it is the ballast? it seems a little weird that the lamp and ballast go out at the same time.
