I have a ZTE cell phone from metropcs it fell in the toilet i quickly got it out dried it, it seemed okay for about 2 hours then my screen went blank it turned all white i took the cell phone apart to try and dry it out but i dont know what to do anymore everything else on the phone works fine i can hear it ringing the keypad works but the screen is blank i need some advice please thanks!!!!!!!!!!!!!!
SOURCE: Water Damage!
its probably behond repair as Im not sure what you paid for that model but there sell here in the states for 79.95 US. I kind guessed you were not in the US as you said loo!!(he he} just a luck guess I guess/?
SOURCE: dropped razor in toilet
Sounds like it is done for, yes. I know a way to save electronics if they are dumped in water, but it requires to fill it with water replacing fluids. Putting it in pure alcohol right away (remove battery first) might save it, as ir should replace the water and then evaporate completey when you take it out. Some contacts have probably corroded in your phone, so unless you are (or know) a repairman of electronics you'll probably need a new phone. :-/
SOURCE: cell phone
if the phone didn't get wet or u can't see a visibly broken screen then ur lcd may still be working, u simply may need to re seat the ribbon cable that connects the lcd by un screwin the 4 screws that hold the display n pryin in open from the mid section of each side then use somthing flat to lift the connector n replacing it pressin firmly.
SOURCE: cell pjone water damage
Unfortunately it may be too late...the phone should have been turned off the battery should be taken out as soon as it was taken out of the water...this keeps circuits from shorting out...
BUT...it never hurts to try everything...
Place the phone in a sealed container full of uncooked rice, and leave it there for at LEAST 3 days...thats 72 hours of not powering it up...as tempting as it is to "check"
You have to give the rice time to draw out any moisture.
Hope this helps.
SOURCE: Razr cell phone got wet, now one number on keypad will not work.
since it got wet, the company cannot fix it. i'm sorry
