Watches Logo
Posted on Mar 16, 2010
I have an old ladies dress Chopard watch - oval shaped gold with diamonds on the band. I inherited the watch from an estate. I wore the watch from a month and then it just stopped. Should I take it to a dealer here in my city, or send it back to Chopard?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12199
Points
8
You need to first know if it is a Quartz watch or an older Wind Up type. I am guessing, since you have been wearing it and do not mention winding it, that itt is probably a Quartz movement in the watch. However, to be clear, If it is older than about 1970 then it is definitely Not Quartz. Then might be what is called an Automatic movement, which is actually a Self Winding Movement mechanism. If newer than 70, could be either Quartz or WindUp. If it is Quartz then the problem is most probably that the watch needs a New Battery. This can be done at a local jewelry shop for around $8 to $15. If it is a Wind Up style then it would need a more complex repair. But sending it to Chopard is still the Last Resort as Chopard could charge you $400 to repair it, I am not kidding, haha. But take heart, most probably you have simply got a Dead Battery and your friendly local watchmaker or jewelry store can fix it for you fast and cheap. Good Luck, W.
2answers
I need help finding how old a womens Seiko watch it has two set of numbers can u help me
Farrah, Contact Seiko or try Google search your watch Seiko # and see what comes up then try the second #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ladies Watches
Seiko Ladies Gold Dress Watch Maroon Dial Gold Mesh Bracelet Ca 1970s
Seiko ladies watch Gold with maroon face Google Search
How to change time on a chopard happy diamond watch
There is a depression/recessed button in the back of the case. The watch comes with a stylus for poking it, but I'm told just about anything pointy, even a toothpick will do. It only works if the watch is functioning. If the battery is dead, it won't do anything. You can make short pokes to make small adjustments, or press continuously to move the hands faster for large adjustments.
Need appraisal on my grandmothers old bulova watch, serial # 1518119. It has links as its bracelet and is attached to the watch on its side with clips
Without more information, such as a picture of the watch or more information about the case, it is difficult to provide a value for this item. In general, vintage fancy ladies watches (the kind that are approximately the diameter of a U.S. nickel or smaller) are not very collectible. As recently as a few years ago, these were bought and sold in bulk for only a few dollars each. In nice cosmetic condition and running properly, a Bulova ladies fancy dress watch in a steel or gold-plated case might retail for between $15-50 at an antique mall. They might sell for somewhat more at a jewelry store that stands behind the accuracy of the movement, but because the inventory of these watches is so large and demand is fairly small, prices for these watches remain much more modest than similar age men's mechanical wristwatches.
Some valuation exceptions do apply. Certain brands of watches, such as Rolex, IWC, Blancpain, and other premium brands, are worth much more than common brands like Bulova. Ladies watches with sweep second hands, as opposed to fancy watches that just have hour and minute hands, are more desirable and are also worth somewhat more than average. Also, watches in solid gold, platinum, or silver cases--or watches with diamond chips or ornate cases--are also worth at least their "melt value" as scrap metal or have an independent value as fine jewelry. All precious metal cases must be labeled; if they are not labeled on the outside of the back cover, they should have be marked on the inside of the back cover (you'll need to carefully take the movement out of its form-fitted case to see this). Be aware that "14k RGP" or "rolled gold plate" on the case means it is not solid gold. Similarly, cases that are "warranted" for 10, 15, 20, or even 30 years are also gold-plate, not solid gold.
Today, with the increase in gold prices, many people have been buying these watches to melt down the gold-plated or gold cases for their gold value, throwing out the watch movements and watch bands. This may have a long-term impact of raising the value of these watches in the long term, as this is decreasing the supply of available watches of this type (it's also frustrating to watch collectors to see the watch movements discarded, as these are valuable sources of replacement parts that are no longer made). However, tens of thousands (more likely hundreds of thousands) of these watches exist in the United States alone, so there is little likelihood that these will become scarce in the immediate future.
I have a Relic ladies watch that I wear all the time and just love. I recently had the pin to brake that holds the watch to the band. The jewelry store repair man had to drill the pin out to replace it...
mcdevito75 here, That pin is called a spring bar and is used to hold the band to the watch, the pin must be frozen in place on the watch, Best Bet is to try another jewelery shop, in the meantime you can put a drop or 2 of cooking oil on the pin just as it meets the watch this may loosen the remaining portion of pin.
2answers
How does one change time on a Chopard Happy Diamond Watch?
mcdevito75 here, Best Bet see a small watch repair shop in your area, Web didn"t help too much, Sorry.
I own a gold tone diamond accent jurgensen(like the silver tone) and I need to replce the interchangadle 1 piece watch band. It's hard to read the watch case # but I think it's 7324QS. My current watch...
you can buy on line try ebay extra long strap 8mm or through the manufactors you should have no problem state buckle color as well a company called Hirsch sell high quality straps and bracelets they surply most of retail high end companys with their straps.
10helpful
My extra watch links are nowhere to be found!
I did check Chopard's official site and no match for your watch was found there.
That makes me think that you have Chopard replica (fake) watch.
In both cases there is a solution, but this will take your time as you will have to browse through plenty of websites to find an exact match.
I can not do it myself as I can not see the watch and do not know what type, shape and size of links you are looking for.
To check the original Chopard wabsite for yourself, follow this link:
chopard.ch
If you will not find there what you are looking for, then type in your browser:
Chopard Happy Sport 27/8236-23 and hit Enter.
This will show numerous listings of Chopard Happy Sport Replica sellers and resellers. Go through as many as you like till you find the right one.
Do not forget to rate, please.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
