Try to charge it from other Power points, Check connection/direction of your battery & clean contacts of battery terminals.
If this will not solve the problem go to nearest dealer for repair (service), may be there is some problem with inner circuit.
Have a nice day...
I know this system well. Others have complained about the same problem which is why Gibson has come out with a new version. You probably need to change tuners. Sorry...
Clean the contacts on the battery and the charger with the eraser on the end of a common pencil. Insert the battery and see if it will take a charge. If it won't take the battery and the charger to radio shack and have them test each one. Joe
Note, I just put in a new battery, and used a spare charger that I bought as brand new. It wont go into the charging mode!
I have an Gibson sg robot guitar that I let the charge run down below the notice of low charge wher you need to do an emergency charge or reboot and now with following Gibsons instructions it wont go into the charge mode and charge.I put in a new battery, and am also using a new charger. So a pencil eraser just wont get it.Please respond if you now, or I can use a refund. Thank you!
