you can perform a hard reset by turning off the device by using the stylus to push the reset button of the phone, while holding the two striped buttons. then follow the insturctions on the display if they are shown. if not, the display is broken and should be replaced.
Try Hard Resetting it. It brings your phone to Manufacturers setting. Though You'll be loosing all your data (Try syncing with your comp if you can) but you'll be able to use your handset. Just go through your user manual for the hard reset.
To perform a NORMAL Hard Reset
1) TAP ON START ---> SETTINGS ---> SYSTEM
2) TAP ON THE " CLEAR STORAGE " ICON
3) ENTER 1234 & TAP " YES "
IN YOUR CASE DO HARD RESETTINGS AS MENTIONDED BELOW
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen:
3)“Press Send to restore manufacturer default, or press other keys to cancel.“
3. Press on your device.
YOUR HTC P3300 BECOME LIKE NEW ONE WHEN PURCHASED IT USE IT 1ST TIME.
NOTE : ALL ADDITIONAL PROGRAMME LOADED BY YOU AND CONTACT NOS PHOTOS VIDEO SONGS STORED ON MAIN MEMORY WILL BE VANISHED AFTER HARD RESETTINGS SO PLEASE THINK TWICE BEFORE DOING HARD RESET !
PLEASE RECHARGE HTC P3300 BEFORE PERFORMING BOTH HARD RESETS
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost. You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain. To perform a soft reset • Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
To perform a hard reset
Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
try aligning the screen... settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e. press the two soft keys and the reset button using stylus...
If its still not working do soft reset: settings > system > Clear storage but remember to take back up of phone before doing this..as it will erase all your data...
