Maytag 20 cu. ft. Upright Freezer MQU2056B Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag upright freezer with self defrost. The water line freezes.
Maytag upright freezer with self defrost. The defrost line freezes up ?
Anonymous
Level 3:
  • Master 389 Answers
  • Posted on Apr 21, 2010
Anonymous
Master
Level 3:
Answers
389
Questions
Helped
141986
Points
1027
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
Our upright frigidaire freezer leaks water......not all the time...just every now and then
turn off power to frig or unplug and let it defrost, if water drips inside and no water drips in the pan on top of the compressor after defrost then the drain line that goes to the pan is clogged. also sometimes the pan itself develops a leak, but that will be self evident. If this resolves problem for a period of time and problem returns then probably defrost timer
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
1helpful
I have an Maytag upright freezer.Does it self defrost?if so how does it self defrost?Do you have to leave the plug and hose out all the time? model # is rfu1500aaw
This is not a self defrosting freezer . Remove the plug and hose ONLY when you unplug to defrost . You should defrost when the coils get about 1/4 " of frost (ice) on them . Otherwise , the frost will act like the plastic insulation on electrical wire , not letting the coldness freeze the food solidly .
I have a maytag freezer does it self defrost?
If it has a fan in it, it's self defrosting. The moving air burns away the frost and 8 out of every 24 hours, the defrost timer will turn a heating element in the cooling coils, to melt away any ice buildup.
If it isn't a self defrost model, you can safely defrost it woth a pan of hot water. I also use a spray bottle woth hot water to help the process. DON'T use anything electrical to make the heat. Water can drip into or onto it and you could get electrocuted.
How to recharge freezer electrolux FFH17FC7CW0
HI, It is a big job to recharge a unit. If it need recharged, it means there is a leak. Do you have any cooling at all? If this a self defrosting freezer? If it is self defrosting, make sure there isn't any frost building up on the evaporator panel.
Vic
Deep freezer drain
drain hole block-up. u need to defrost freezer
Apr 12, 2008 • Freezers
Upright freezer
no light in unit??? check the bulb, reason i say that is you should aa least have lights on, check the recepticle its pulgged into
2answers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
