I have a 2001 acura integra. when i first bought the car it had a kenwood kvt-617dvd deck in it. i took it out a put in the factory deck because the laser wouldnt read disks(i assumed it was burnt out). now all my music comes from my ipod so i dont need cds anymore and i like this deck so im trying to put it back in. when i have it all hooked up and try to open the screen it folds up and gets half way to where it sits it stops and displays there is a wire/cable not connected and i cant figure out where this cable is?
SOURCE: BYpass kenwood kvt-617dvd
Ground the Green "Brake" wire to your frame. This will fool the system into thinking that your brake is engaged.
SOURCE: kenwood kvt 715 screen saying disconnected cable found
same problems would like it if you could tell me how you resolved it, many thanks
SOURCE: Kenwood KVT-617DVD - Rear Camera Option Not Working
Since "...everything else is working..." indicates that there is no blown fuse or chances are nor any hardware is at fault.
When the battery was disconnected, the Kenwood KVT-617DVD may have suffered a memory failure and would require a reset.
Have you tried doing a reset? It's a small recessed button near the bottom right side of the font panel underneath the protection panel (right of the Joystick Track/Station Key & above the Eject Disc Key). Pressing the reset button should restore the Kenwood KVT-617DVD to default factory settings. Of course this will also remove any special programming that you may have such as favorite stations, etc.
You also posted "...Parking brake requirement...bypassed..." this is only to allow the display to be always ON. This is the green wire that must be grounded
You need also to check that the "Reverse" wire/trigger is also bypassed that is to set the "...camera...full time...rear view mirror and back-up monitor for the truck camper..." This is the pink wire that must be attached to the ACC of the vehicle's Ignition Switch. Alternately, it may be connected to the red wire of the Kenwood KVT-617DVD.
If the reset does not correct the problem, you may need to run the setup menu again following the user's manual. Should you need a copy, it is available on line here. Pls verify that you set R-Cam Interruption to ON & R-Cam Mirror to Reverse. This is better explained with appropriate illustrations in page 69 of the User's Manual.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
SOURCE: Kenwood kvt-717dvd
Your unit has a security code programed.
There is a way to clear the security code,you just need to Point the remote control to the screen (while code request mode) and enter the follow numbers 55222277.
If you make a mistake press any number or reset the unit and start over again.
NOTE: You will not see any change on the screen until you enter the last number.
LET ME KNOW IF IT WORKS
Thank's
