1999 Chrysler 300M Logo
Posted on Mar 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace a idle air control valve on a 1999 300M Chrysler
Need to replace a idle air control valve on a 1999 300m Chrysler 3.2 engine. How do I proceed?
Greg Bernett
Level 3:
  • Chrysler Master 2,993 Answers
  • Posted on Mar 06, 2010
Greg Bernett
Chrysler Master
Level 3:
Answers
2993
Questions
Helped
2783174
Points
13428
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the IAC electrical connector.
  3. Remove the IAC mounting screws.
  4. Remove the IAC.
To install:
  1. Install the IAC to the throttle body.
  2. Tighten mounting screws to 5.1 Nm (45 inch lbs.) torque.
  3. Attach electrical connector to the IAC.
  4. Connect the negative battery cable.
  1. Disconnect electrical connector from IAC motor.
  2. Disconnect air plenum (where applicable).
  3. Remove two mounting bolts (screws).
  4. Remove IAC motor from throttle body.
need to replace a idle air control valve on a 1999 - 3ccd55e.gifmg src="/uploads/images/3ccd55e.gif" alt="3ccd55e.gif" class="h_mi" />
To install:
  1. Install IAC motor to throttle body.
  2. Install and tighten two mounting bolts (screws) to 60 inch lbs. (7 Nm) torque.
  3. Install electrical connector.
  4. Connect air plenum (where applicable).
1helpful
3answers
Which fuses would affect my idle control valve and what voltage should the wire harness show it has 4 wires.2000 dodge durango 5.2 engine
There is no one fuse that powers the idle speed control valve (AKA Air Bypass Valve). It receives its power from the electronic engine control system (known as reference) and that is controlled by the computer depending on the idle load on the engine the voltage varies. So if the system reference voltage was lost then no part of the engine control system would function.
1helpful
2answers
How to replace a intake plenum gasket
Well basically, you remove the intake plenum and replace the gasket and reinstall the plenum. Here are the steps:
1. Disconnect the negative battery cable from the remote jumper terminal located at the right strut tower.
2. Remove the air inlet resonator and tube.
3. Remove the throttle actuator cables from the throttle arm and bracket.
4. Disconnect Secondary Runner Valve (SRV), Manifold Tuning Valve (MTV), Throttle Position Sensor (TPS), Idle Air Control (IAC) motor electrical connectors.
5. Remove the electrical connector and the Intake Air Temperature/Manifold Absolute Pressure (TMAP) sensor.
6. Disconnect vacuum hoses from the Secondary Runner Valve (SRV) reservoir, Speed Control reservoir, and PCV.
7. Remove right and left intake manifold supports.
8. Remove support brackets at the intake manifold front corners and MTV.
9. Loosen upper fastener attaching throttle body to support bracket.
10. Remove clips attaching EGR tubes to intake manifold.
11. Remove intake manifold bolts and manifold
12. Remove old gaskets, Clean gasket surfaces, and install new gaskets.
13. Reverse steps to reinstall manifold
P1299 code after replacing the plenum gasket. Rough and sometimes erratic idle.
This code indicates a large vacuum leak. You can sometimes find a leaky gasket by spraying ether on the gaskets while the engine idles. If the engine changes speed while the gasket is sprayed, you have found the leak.
Chrysler 300m starts at high idle in cold weather
First check the error codes. they can be a lifesaver. Physically look under the hood for cracked or leaky vaccuum hoses. High idling often indicates a vaccuum leak somewhere. look at the vaccuum elbows on both the right and left side of the engine just about midway down the engine from front to back on the plenum- that's the big, black flat assy that channels the air as it goes into the engine.
Once again the codes can tell us alot.
2helpful
P1299 code 300m chrysler
code PO1299 = vacuum leak found
check all the vacuum hoses going to the upper intake manafold if all hoses check out ok then replace the idle air control valve.
the onboard computer syatem can not control the idle, it is to idling to high.
High idle o n a 1996 chrysler concorde. have change the tps and the idle air control valve. i think its a vacum line but i dont know which one. which one s effect the idle
High idle is usually caused by a vacume leak. First place to check is the cold air intake manifold. All hoses, throttle body, and sensors. Throttle Position(TPS), Mass Airflow(MAS), Idle Air Control Motor (valve) IAC. Controls Idle speed
A malfunctioning throttle system can cause both a high idle as well as an engine stall.
A dirty air intake or cracked air intake tube is often the culprit.
How to Fix an Engine High Idle in Under 15 Minutes
Hello i have a 2001 chrysler 300m, 3.5 engine with code p0505 i already put a new iac and cleared code and i came back with the same code p0505, also the idle gets stuck on high rpms. and even if i...
well the ecu try to control the idle but if there is a leak on the intake maniful after the trotlebady it can not control it check for vamum leak may be a hose the pcv valve hose on the intake
2helpful
3.2 liter yamaha engine manual IAC valve How do I replace the IAC valve on this engine? Steps? I just bought a new one and I need to get it replaced. FORD 1994 Taurus SHO 3.2 liter engine YAMAHA
may just need cleaning with carb cleaner.
here is 1996, oldest I have:
Section 03-14: Engine Controls, Electronic 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Idle Air Control (IAC) Valve Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Disconnect the engine control sensor wiring (12A581) from the idle air control valve (IAC valve) (9F715) at the idle air control valve electrical connector.
  1. Remove the two idle air control valve retaining bolts.
  1. Remove the idle air control valve and idle air control valve gasket.
Installation
  1. NOTE: If scraping is necessary, be careful not to damage idle air control valve gasket surfaces, or drop material into intake manifold (9424) or throttle body (9E926) (depending upon application).
    Clean idle air control valve gasket mating surfaces.
  1. To install idle air control valve, reverse Removal procedure.
  1. Tighten the idle air control valve retaining bolts to 8-12 Nm (71-106 lb-in).
1helpful
I am experiencing problem with my car
check idle are control, could be clogged with carbon from engine. if it is badly clogged it will not run proper. you can take it off and clean valve. but do not put in any liquid. use a old brush to clean out valve on end, do not push on valve or it will mess up setting! clean where it mounts to engine also. hope this helps CARL,
3answers
2001 300m overheating problem.
When the vehicle overheats, do u check the water/coolant level in the radiator? If it has reduced, it means ur leaking and u should inpsect to c where the leak is coming from. If the level has remained the same, probably ports are blocked or something to that effect. Keep me posted though
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
