Re: Why is error code F8E0 appearing on my Baumatic...
I have a B205SSA and the error code F8EO is appearing eveytime i have used the oven, i then have to reset it by turning off and back on again at the mains.
Any ideas? Cheers. Rich.
It is a thermal limiter. Same happened to me with kenwood . Am in the process of sourcing repacement. Can only find on the overpriced sites at mo eg partsmaster
1. Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad
(also called touch pad or membrane switch). Some models incorporate keypad
in to control board as one unit. In this case, replace control board (also
called ERC or clock).
There should be a small plate or label on the oven, giving all the details you require.
It could be at the bottom, or inside the door opening, on the rear, on the top of the oven itself, it will be there somewhere, unless it has come off.
Hope this helps.
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
