For the YTH2246 only...
1. All you need for this job is a small 1/4" ratchet and a 3/8" socket to install/replace the 1/2" X 106" V-belt [(no. 68 in the mower deck schematic for this tractor) Husqvarna part # 532 40 51-43, Sears part # 33156, Rotary Outdoor Power Equipment Service Parts part # 912106 (12-7549)] ($36-$42)
2. Total time for this DIY job: about 15 minutes.
3. Lower the deck by moving the manual height adjuster to the lowest position (position 1).
4. The only screws you really need to remove are the rear retaining 3/8" hex-head screw of the LH cover mandrel and both from the RH mandrel cover. Just swing the left-side cover out to get access to the LH pulley.
5. Slightly pull from pulleys the legs of the keeper belt mandrel LH/RH to remove/insert the belt. Did I mention you don't need to loosen/remove any screw other than the ones mentioned above?
6. For more assistance, take a look at the schematic in the owner's manual or online at http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602060.pdf
