Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Unfortunately, to get at the interior of the handle unit, it's the final stage of the taking apart. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. (You can give your glass a good cleaning at this point also.) There are 2 bolts to remove to free up the handle unit, and now you can easily tighten (or replace as needed) the 2 pairs of handle bolts. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
