Dometic Rooftop RV Air Conditioner Logo
Posted on Feb 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can we tell if our dometic rooftop air conditioner/furnace has a heat strip or not.
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 99 Answers
  • Posted on Feb 23, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
99
Questions
0
Helped
20601
Points
147
Hi; If You have a heat pump then yes on heat strips. Does Your RV have a gas heater. If You gently remove the cover some times You can see the heat coils in the metal air flow tube...Also does the compressor run in heat mode ,if not then best guess You have heat strip capability...alpharome416
  • laspeyrer Apr 19, 2015
    look at your thermostat,it should say,off/cool/furnace/heat strip, if it does not say heat strip,it probably does not have one
Where can I get a heater kit no. A70011 for a SL110RB dometic-aire roof-top air conditioner?
Any dealer should be able to order for you. Here's dometic site to locate nearest dealer to you.
https://www.edometic.com/allusr/srvctr.nsf/dl?OpenView
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Rv heat pump problems
Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-point. There is a sensor that detects evaporator freezing, it may be bad or your freezing because of low freon levels
It is getting cold can you tell me how do i work the furnace part of my duo therm dometic air system
I hope this doesn,t sound patronising but i have seen people turn the themostat down to make the furnace come on obviously the thermostat has to be turned up to set for a higher tempreture , after a small time delay, should then light up.
I got a Dometic roof AC (2010) on my RV , the thermostat is givng me a E5 code, I changed 3 thermostats, opened the top and inside caps to check if there's any cut or burned wires and nothing that I...
E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification
operation will be locked out. Heat pump, furnace, heat strip and fan operation
Sounds like your freeze sensor is defective and since it is still under warranty, you would void it if you replace it yourself.
1helpful
I have a 15000 dometic airconditioner and would like to have a heat strip installed , where can I get the heat strip and instructons to install it?
You can get the heat strip at your local heating air distributer try looking for cc dickson company you will need the model number and serial number
1helpful
Furnace and Air conditioner run at the same time
Odds are u did just that or wrong thermostat,If u don't have a digrahm get one from Library.
Dur-therm furnace heat controll with Dometic remote
i would suggest that you look at your thermostat,it may be to close to the furnace keeping in mind that all thermostats have a certain tempreture drop (or gain) before restarting john
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
