Lexmark Z645 InkJet Photo Printer Logo
Anonymous Posted on Feb 27, 2008
Printer I've just bought this Lexmark 640 series computer well thats what it says on the disc but the printer says Lexmark Z645 and it will not print at all and im sure that I've got every thing set up right.The first time that I've hooked it up to another computer it worked fine but know that I have it to another computer it's not working...any solutions.Your help would be great!!!!
  • Anonymous Feb 27, 2008
    how do you reboot your printer
Anonymous
Level 3:
Master:
  • Master 518 Answers
  • Posted on Feb 27, 2008
Anonymous
Master
Level 3:
Master:
Answers
518
Questions
0
Helped
249254
Points
1328
Try this:
1. From Control Panel > Printers... delete all printers.
2. Unplug the usb cable.
3. Re-boot
4. Install software
5. Plug in usb cable.
Hope that works for ya...
Geno
Hi, I own a Lexmark z645 printer and an airport express . Everything is installed but it doesn't print anything. Is this printer compatible with APE? Thanks
What is the operating system installed on your computer?
Note: The Lexmark Z645 printer only works on Windows operating system. Unfortunately there are no Lexmark Z645 printer drivers available for Macintosh operating system.
My computer is saying my Z645 is a 640 and i lost disk so i cant get it to work or reconize it?
You can download the Lexmark Z645 driver from the Lexmark website for free. Click on this link Lexmark Z645 Drivers. Select your operating system by clicking on change OS.
Then click on FILTER.
Click on the Complete Driver under Recommended Downloads. Download, execute the file and follow the instructions on the software. NOTE: Lexmark Z645 is supported on Windows only.
I hope this information has been helpful. Thanks.
Load a LEXMARK Z645 printer without a disc
Here's the link to the Lexmark Z645 drivers for Windows operating system: http://bit.ly/cZiQ1r. No available drivers for Macintosh. Choose the correct driver compatible with your computer's operating system and execute the file. Thank you for choosing Lexmark.
6helpful
5answers
I have misplaced the download disc for the lexmark z645,could i possibly get a replacement from you?
HELLO THERE:
I do not have the disk but i do have several links here that you can get the download from i would suggest that if they offer you the full suite use it it gives you a lot more features to use with this printer ok just look at the links below I hope this is very helpful
best regards Michael
  1. Lexmark Z645 Driver Download Lexmark Z645 driver download. To download Z645 driver read the instructions below. ... Home Lexmark Printer Z645. Download Lexmark Printer Driver. May be useful ...nodevice.com/driver/Z645/get65147.html - Cached
  2. Lexmark Printer Driver Download Lexmark driver download. On this page we place a list of Lexmark ... Lexmark. Z645. Driver for Lexmark Z640 Series. Windows Vista x64 / Windows 7. Download ...www.nodevice.com/driver/company/Lexmark/Printer.html - Cached
  3. Lexmark Z645 Driver download - Soft-Go.Com Lexmark Z645 driver download for your printer device ... Lexmark Z645 is intended to be used with following operating system(s): Windows 2000,Windows XP ...www.soft-go.com/download_driver/Lexmark-Z645_37.html - Cached
  4. Lexmark Printers Drivers - Download Drivers Free - Page 4 Lexmark Printers Drivers free downloads: lexmark x422 mfp pcl and ... LEXMARK Z640 Z645 Z645 Z647 INKJET PRINTER V1.0.3.1 WINDOWS VISTA X64. Lexmark. Item Title ...www.lostmydrivers.com/printers-drivers/lexmark/page_4.html - Cached
My computer will not even acknowledge a print command. Will not print anything, It is sent to "print online! it is set as default printer as 640 series. There is plenty of ink, yet is showing as; Ink Low ?
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
1helpful
Lexmark Z645 can print locally, but will not print off of citrix
Lexmark X and Z series printers do not function in a Citrix environment, see page 4 on the following document.
ftp://ftp.lexmark-europe.com/brochures/de/solutions/citrix_basic.pdf
2helpful
Lexmark all in one printer don't install on vista. is there a patch
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
exmark
  • Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
  • Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
  • Lexmark X5400, X4200, X1200, Z645, Z840, Z730, X2400, X3400, P350, X7300, X8300, X9300
  • Lexmark X1100, Z500 & Z600 (combined), P4300, X3300, X2300, X7100, Z810, Z700, X5200, P6300, P910, P6200, X6100, X5100, X2200
  • Lexmark 1100, 1200, 2400, 3400, 4200, 5400 Series, Lexmark X7350, X8350, X9350, P350, Lexmark 640 Series, Lexmark 730 Series, Lexmark Z845[4]
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
