Intel D101GGC Motherboard Logo
Posted on Feb 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intel D101GGC Motherboard front headphone mic not working becoze wire not attach in motherboard
  • 9 more comments
  • Anonymous Mar 11, 2008
    my front panel heaad phone wires are not attached...how to attach
  • taktor Mar 29, 2008
    i cant connect the usb front panel, the motherboard has 2 sets of pins and the wires are marked as (usb1+g) and the other (usb2+g) please help me attach them.
    many thanks
    taktor
  • Anonymous Apr 25, 2008
  • leolov2001 Apr 28, 2008
    i lost my manual for my motherboard....
    right from i bought my PC, my front audio which basically is for head phones was not working...
    i opened the cabinet and the pins were connected, but still no audio from them... my guess is that the pins were not connected properly...
    does anyone have the manual and can scan the page and load it up online... so that i can even see the pictures and connect it accordingly... thank you.
    P.S: i have seen a similar question on board but the answer was simple " connect the pins".... my point is how? please help me.
    Thanks in advance.
  • Anonymous Jun 05, 2008
  • jomonjacob Dec 07, 2008
    i am facing same probelm
  • biswasrao Dec 14, 2008
    Intel D101GGC Motherboard front headphone & mic r not connect to motherboard.tell me the pin configuration..
  • shubham123 Dec 17, 2008
    Intel D101GGC Motherboard front headphone mic not working becose wire not attach in motherboard problem
  • Anonymous Mar 18, 2014
    the leads say
    mic in
    mic bias
    ground
    spk out l
    spk out r
    return l
    return r
  • Anonymous Apr 04, 2014
    for USB connection, the header is normally 9 pin 2x5, and 10th pin missing. now if you can identify pin one that is at the opposite side of missing pin. that's positive and from there 4th one is "g" if your connector is 4 pin in one body then simply align pin 1 to + and g to 4th and for second connector just match the +and g and insert. and if that's not helping just post the photos of bother here then I will tell you exactly how to do it
    and front panel audio won't work coz it requires special front panel that can send the sense input for speakers and mic.
Anonymous
Level 2:
  • Expert 108 Answers
  • Posted on Feb 24, 2008
Anonymous
Expert
Level 2:
Answers
108
Questions
0
Helped
70183
Points
283
Simple dear connect the wire on Motherboard. The pins you will get near the outer portion of your motherboard.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
792
Points
It wont work even if u connect wire to MB it requires special hd wire (with sence) or u can configure audio panel one comes after driver is installed to stop looking for pin iscertion and do its fancy popup thingy.
2helpful
2answers
How do I hook up the 2 audio outputs from CD-ROM on Intel D101GGC
You shouldn't need to connect audio connections from drives to the motherboard unless you are using A Win 9x operating system. Digital Audio Extraction is used for WinXP and later and the analog cables are no longer needed
Sorry no info on the pinouts
I can't here voice in my headphone or from my cd drive,mic is also not working
dude check the connection the if thats correct check the sound & audio devices setting in control pannel are they active or not. and by active i mean they should not by muted
1helpful
Could you please help to connect the front panel headphone connection to the motherboard
Here is a link to this motherboard's manual:
http://download.intel.com/support/motherboards/desktop/d101ggc/sb/d3458804_en1.pdf
On page 38, you will find the connection diagram for front panel headphone connection.
1helpful
Hello i use Motherboard Name Intel D101GGC my
try mic in front panel..to use on back panel, uou have to change option on sound settings near the clock on right-down corner goto>recording>unmute or check rear mic.
thanks
Headphone problem
Did you installed all drivers ?
Are there FRONT audio jacks you are trying to connect your headphones/mic ?
Dit it work before ?
First install all (incl. audio) drivers and try to get audio from BACK connectors (Green is speakers/headphones, Pink is Mic.)
If it workson on REAR, but not on FRONT connectors, check if you have another icon for AUDIO settings in Control panel and try to set FRONT audio settings.
Check if FRONT audio connectors are connected to your motherboard.
Regards.
Check
3answers
Mic not detecting
The Board have three sound port one for rear one for front and one for mic plug in the mic pin into the mic port red colored.
Then go to the realtek control panel located in the taskbar like a red speaker open it and go to the I/O
options and the mic options turn on front mic.
2answers
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
