hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://www.badcaps.net http://en.wikipedia.org/wiki/Capacitor_plague Replacement board:
You will have to open it up and inspect the inside for capacitors with bulging top or seal, or leaking caps first.
Report back what you find so we can guide you further. It can be bad caps, transformers, transistors, bad solder joints, etc.
You can buy replacement board from here (must verufy which version you have): http://www.lcdrepair.us/Invpowersupply.html
See soe pictures here as a guide to see what goes wrong with Dell and other monitors: http://s807.photobucket.com/home/budm/allalbums
You have either power supply or inverter circuits failure, worst case will be lamps. Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further. http://www.badcaps.net http://en.wikipedia.org/wiki/Capacitor_plague
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further.
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Flashing power LED light means you may have shorted (Emitter to Collector) out transistors (c5707) or bad fuse (fuse has high resistance) PF751. Those are what you need to check. see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
The blinking power light usually indicates a blown power supply board. We have a step by step repair guide posted on our web site at: www.ccl-la.com If you don't want to do the repair yourself we do offer a repair service. If you have any questions just contact us at the address below.
I hope this helps, If so please rate our solution.
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
