Logitech QuickCam Messenger Web Camera Logo
Anonymous Posted on Feb 03, 2010
I can't find the driver of my cd-r king pc camera model VC2P
My drive can't read the installation disc
Mac
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 34 Answers
  • Posted on Feb 03, 2010
Mac
Contributor
Level 1:
New Friend:
Night Owl:
Answers
34
Questions
0
Helped
29712
Points
87
Try an online search for king PC camera drivers and see what comes up, or go to the manufacturer site and look for driver downloads, that should solve the disc reading issue, however if your drive can't read it, maybe the disc file has become corrupted or your optical drive is failing. Also go to my computer, drive C, programs folder and see if the camera software is in there, chances are you can reinstall it from its original folder.
How do you get the install disc online if your computer want read the disc super multi drive install disc for windows
These days not many disc drives need external drivers. First I would check in the device manager, usually accessible from the control panel and see if the disc drive is listed. If it is and there are no notifications it probably doesn't need any other install. If you select it and right click then select properties it will tell you if its working OK and which drivers are installed. If there is a problem select reinstall or update driver and it will search for one and install automatically. If it can't find one and there is still a problem simply use a search engine put in the name and model of the drive then free driver download, there will be instructions on the site.
My Toshiba Model L505-S5993 laptop won't read
Hello there,
The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
Hope this was helpful to you.
Goodluck
Elect_Comp
2helpful
4answers
I need a web cam installer for cdr king ao series
Good Day Anne!
I could have pointed you directly to the AO web cam installer driver that you need if you have mention the model number.
Anyways, the visit CD-R King's download site for its products, go to
http://www.cdrking.com/?mod=downloads
Scroll down below until you reach the PC Cameras category. Select from one of the AO series that match your web cam.
I do recommend you disconnect first the web cam from your PC before installing the web cam driver. You will only connect it during the installation once it prompts you to connect it.
Enjoy it!
It would be nice if you could give some ratings and testimonial to my answer.
Thank you asking Fixya.
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
1helpful
2answers
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
4helpful
I need driver for cdr king c series c080701561
DOWNLOAD DRIVER FROM THIS LINK
http://www.freshwap.net/4c9/dl/Cd+R+King+Webcam+C+Series+free+Installer
THANKS
My laptop is unable to read external device (disc of photos). Had ability to do so until hard drive crashed whilst still under warranty (no longer under warranty now). The only drives on computer now are...
Make sure that your source disc is compatible with your drive. if it has a dvd, then you can use dvd disc.
Also, try to download and install the DVD/CD driver for your laptop.
2answers
Hard drive not Reading CD-R Discs
First off. Your hard drive cannot read CD's. Your CD-ROM is not reading CD's. Well a few things can be wrong there. 1. The CD-ROM is dead 2. The drivers for the CD-ROM needs updating 3. The CD that you are trying to read is curropt or damaged.
Start checking to eliminate and let me know.
1helpful
2answers
Epson Stylus SX100 installation CD is not read
There are chances that the installation CD is faulty itself. If it is the original manufacturers installation CD, and appears to be free of scratches and smudges, this is most likely not the case. I would insert a combination of at least one other software CD and one recordable CD in the CD drive of your computer CD/DVD drive to see if these discs are being scanned, read, and show data on those CDs. We want to pinpoint the problem, to make sure that the hardware failure of CD Drive is not to blame, but it could be.
A Disc can spin around in an optical drive, and have laser read issues, and still end up being faulty, and eventually need to be replaced.
If you determine that you need a new Printer installation CD/DVD, and all other data discs work fine in that optical drive, you can download printer driver software directly from the manufacturers web site.
If you provide me all the model and manufacturer details of your new printer, I can locate this direct download link for you, and provide that to you.
Best of Luck!
Xpertdragon.
CD ROM ONLY READS CERTAIN DISCS
uninstall the drivers on cd rom.then restart the pc the pc will reinstall them
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
