Kenmore 64802 Top Freezer Refrigerator Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator top freezer leaks into the bottom refrigerator.
Anonymous
Level 2:
New Friend:
  • Expert 119 Answers
  • Posted on Jan 31, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
119
Questions
0
Helped
15907
Points
293
THE DEFROST DRAIN LINE IS CLOGED YOU NEED TO REMOVE PANEL IN FREZZER AND FIND THE DRAIN HOLR MELT ICE AND USE TURKEY BASTER WITH HOT WATER TO CLEAN OUT GLOG
Started leaking water accumulated on bottom shelf in lower level. now top freezer takes 2 days to freeze ice, bottom freezer vent clogged.
The drain is clogged. When the drain clogs it can also clogs the airflow vents. Remove the back wall of the freezer to access the drain. Remove all the ice blocking the drain and the vents. Then use a trukey baser to force hot water down the drain until water flows freely. Then mix water with baken soda and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
4helpful
2answers
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
I have a amana bottom freezer refrigerator that is cooling the top section
i think you mean its not freezing at the top? if this is so, sounds like you have a gas leak, you cannot fix this yourself unfortunately you may require a technician to fix the leak and top up your gas.. make sure they fix the leak or this will happen again. hope i have helped
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
I have water leaking heavily from the inside top of refrigerator,
Water is leaking inside the refrigerator from a bottom vent from the freezer. What is causing this?
Water leaks into the freezer
under refrigerator you soposed to use hot water
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
