Star Manufacturing International Star TSP100  Printer Logo
Posted on Jan 28, 2010
Star TSP 100 do not print in access 2003, access said is over the 22.75" limit
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
292
Points
Miguel963,
I hope you have solved your problem in the mean time (9 months ago!).
I just bought the same printer and ran into the same problem. After looking on the internet for a solution and finding none I read the software manual a couple of times again and came up with this solution.
Access is right when it claims that the report's length is over the 22.75'' limit. The paper size of the 72 mm x Receipt is 72 mm wide and 3,000 mm tall; 22.75 being 577.85 mm. This means that the selected paper size is more than 5 times too tall.
The simplest solution is to choose the 72 mm x 200 mm paper size.
Next you need to go to the properties of your printer (Start > Settings > Printers and Faxes > Star TSP100 Cutter (TSP143)). Select Printer > Properties. In the Properties dialog select the Device Settings tab. Under Installable Options, set the Paper Type to Receipt. Setting the paper type to Receipt will cause the pages to have a variable length.
While you're there you might set the Page Cut Type to No Cut and set the Document Cut Type to Partial Cut.
Works like a charm for me.
If you really want you can even add Access's favorite paper length to the list of paper sizes. To do that you need to go to My Computer > Control Panel > Printers and Faxes. The best way to go there is to use the Windows Explorer or something similar. Under the File menu in Windows Explorer you'll find an option Server Properties. The Print Server Properties Dialog Box is shown. On the Forms tab you'll see a Forms on: <ComputerName> list. Locate the Star paper size of e.g. 72 mm x 200 mm and select it in the list. Once you check the Create a new form check box you can give it a new name. I called mine 72 mm x Access and modified the paper height to the 22.75'' or 577.8 mm.
However, I ran some tests and it doesn't seem like this last step is really necessary. Even with the 72 mm x 200 mm paper size selected for my Access report I printed tickets that were 5,000 mm tall without any problem.
Hth,
1helpful
My star tsp 100 printer receipt is too light to read on the left side of the receipt. It is fine from the middle to the right Help?
Inside the printer there is a thermal printer head that heats the paper to change activate the ‘ink’. It is golden colour with triangle patterns. If this is clogged up with paper, paper dust (clean with isopropyl alcohol and cotton bud) or if the roller isn’t holding the paper against it (check the clips on the lid and the roller isn’t broken). If all this is ok replace the print head.
Star tps 100 not producing reciept intermittantly
Is this the networked Star TSP or the USB version? If it's networked you may want to make sure that you're still connected to the network by printing out a test receipt (power the printer off, hold the feed button down while it's off and continue holding the feed button after turning the printer back on until it prints a test receipt - the second receipt will give IP configuration information).
If you're not receiving a valid IP address you may be having network issues - you might consider assigning the printer (you might need to power cycle your router and printer to get initially connected again in order to do this).
You can also try resetting the printer to its default configuration - you can find instructions here:
Star TSP100Lan Network Troubleshooting Unable to Detect the Printer within...
Why is my star tsp-800 thermal printer offline?
Hi Valued Star User
Please try restarting the computer, this will reset the printer spooler, clear any existing print document and should mean the printer comes back online.
I hope this helps.
For further help please contact us at: [email protected]
Best regards
Star Technical Support
My printer only prints to copies, want one Star TSP 100 future print, how do I change setting
It could be a setting in the driver or in your point of sale software. If you want to check the driver, right click on the TSP100 in Printers and Faxes and click on properties, then printing preferences and advanced. In advanced, make sure the copy count is set to 1.
If you need help assistance with Star Micronics printers, you can contact their technical support at (800) 782-7636 or http://www.starmicronics.com/Supports/TechnicalSupport.aspx .
How to change the printing darkness star tsp 700
To change the darkness settings, use the
printing darkness settings command 'd' n. Refer to the separate
programmer's manual for details.
http://www.star-m.jp/eng/service/usermanual/linemode_cm_en.pdf
STAR TSP 100 FUTURE PRNT
check the roll of paper in the receipt printer. If it is feeding wrong, it will not print. Turn it around. Kathy
Top Star Manufacturing International Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Star Manufacturing International Office Equipment and Supply Expert? Answer questions, earn points and help others
