How does the Bel 980 radar detector case come apart? The internal ground connector on mine is not making a good connection, causing the unit to reset. Thanks y'all.
They are two on back thke the bottem then the top will come off the problem is there are two hinges in the front part on each side u have to compress each side with a very tiny flat head screwdriver. note be very careful this unit is not make to take apart easy but it can be done i have the same problem i am going to radio shack to see if the have the part for the voltage but first i am going to re sader the contection first. hope this works mark
ALGUNO ME PUEDE PASAR EL MANUAL DEL BEL 980 TRADUCIDO AL CASTELLANO
I try to compress it but wich part i have to compress?
3 parts on 980. The top, the bottom or the front.
On top, you have a plate with all the buttons...
Where put the small screwdirver.
Thank's
