go to setting , Bluetooth and delete some of your paired devices after you finish that switch on your phone Bluetooth to visible to all nearby devices also switch your trueblue tb 92ex Bluetooth to connect
Do u have Bluetooth connectivity in both ur Laptop & ur phone?.............if YES then connect both of them by switching on their Bluetooth device and transfer whatever u want. Otherwise please buy a Bluetooth dongle for ur laptop and install it for the same purpose..........
Bluetooth device A looks for other Bluetooth devices in the area
In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
Bluetooth device A finds Bluetooth device B
Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
Bluetooth Device A prompts you to enter a password (PassKey)
With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
Bluetooth device A sends the Passkey to Bluetooth device B
To connect your phone using bluettoth, you need the following things.
1) Nokia PC Suite
2)Bluetooth dongle with the driver installed.
Things to be done on pc side : 1. give your host bluetooth name 2. find BTCOM port My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
Things to do on phone side : 1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
For pairing : 1. add device host: go to My Bluetooth Places->Add new connection phone: go to bluetooth, choose Paired Devices->add 2. provide passkey (4-digit, 0-9 only) on both
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Bluetooth didnt transfer whole songs completeley from computer to phone. somewhere it lost the connectivity between phone and computer while transferring song.
please delete this track from phone and try to transfer again and this time make sure your phone is in very good range or might be very near to computer Bluetooth device.
Is the adaptor on your pc in discover mode. Please come back in as a premium and select me as I had a BT dongle prob as well. I fixed it and I think you have the same prob. If this has proven helpful, please select such. TY
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue. 2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select VOX130 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
providing the mobiles that your trying to connect to are, bluetooth capable devices themselves. it,s the matter of getting the 2 devices to find or recognise each other ( connection Manager ) or device enabled settings.
If your mobile phone is Infa red then the 2 are incompatable. This can sometimes be determined via a little blue flashing light ( hence Bluetooth )
refer to your PDAs user and instruction guide for further assistance.
Mike @ compurepair.
i have also had this problem, i have found that if i get the person to send me something first, there name will appear on the list of bluetooth list, when trying to send them something all you then have to do is click on there bluetooth name and it tends to connect.
hope this helps.
