20 Most Recent
Samsung C6112 Cell Phone Questions & Answers
How to reset the phone lock of GT-C6112
defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
I forgot samsung c6112 phone
Hello thanks for using Fixya
Type #*7337# or try this to hard reset *2767*3855#
Note: Remember one things hard reset will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it
Default phone lock code for samsung if it did'not changed before then it is 00000000 (eight zero's)
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below and then give testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
I bought c6112 duos mobile
My Dear Brother:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
