Maxtor Hard Drive Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
Carlo Barzo
Level 3:
  • Master 530 Answers
  • Posted on May 14, 2015
Carlo Barzo
Master
Level 3:
Answers
530
Questions
0
Helped
128422
Points
1767
Here is the link that will teach you on how set your jumper settings easily from IDE to SATA maxtor hard disk drive
Jeremy Koleske
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jan 25, 2010
Jeremy Koleske
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
10587
Points
91
If you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Hi, Maxtor 90645D3 hardrive deletion manual jumpersettings.
Basic jumper settings for Maxtor ATA Hard Drives
Thank you for purchasing your new ATA hard drive from Other World Computing! Please
review these jumper settings prior to installing your new hard drive into your computer.
You may want to review more detailed information about the installation process, or
the location and configuration of your existing internal ATA drive before proceeding.
Your manual that came with your computer can be of assistance in both of these
determinations.
A few notes about installing an ATA hard drive into your existing system:
Your existing drive is normally configured one of two ways, Master (single drive), or
Cable Select. You will want to determine this before installing your new drive, the easiest
way is to remove the existing drive from your system and visually inspect it's hard drive
jumpers. Most hard drives have a schematic either silk screened onto the case of the
drive, or the schematic is on a label near the jumper pins. If you have difficulty locating
this information, visit the hard drive manufacturer's website.
If your existing hard drive is configured as "Master", then set your new hard drive
to "Slave". If your existing drive is set for "Cable Select", then set your new drive to
"Cable Select" also. You can change the existing jumper settings on the original drive
to suit your needs, but we recommend following these instructions first to verify proper
operation of the new hard drive.
Installing jumpers on the new drive is a simple process, follow the schematic to
configure your drive.
Please note the configuration of
the internal ATA cable already
installed in your existing system.
If your internal cable is configured
differently than pictured here,
you may want to replace it before
installing a new hard drive to
achieve maximum performance.
For further assistance, visit our tech center at http://eshop.macsales.com/Tech/index.cfm
I have a 200 gb hard drive and i need to know where to put the jumper so i can add another hard drive to my system
just have a look at this pic it will help u..
http://common.packardbell.com/PrsPicDwn/08-192-1.gif this is the jumper setting for master... To enable Slave settings just unplug the jumper and leave all the jumpers unplugged....
7helpful
3answers
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Connect it on hardisk enclosure then removed all pins
then connect it usb this serves as an usb flashdisk
2helpful
2answers
I have an older Maxtor hard drive Model 90645D3. How do I put it in slave mode so that I can transfer files to my newer XP's hard drive? Thanks, Rad I think I have the rest of the process figured out.
Hello
At the back of the drive, you should be able to see the jumper setting. There must be a small jumper in as well. Have a look at the pic, and just set it to slave and you should be set.
Kind regards
Andrea
1helpful
I have a maxtor 90645d3 i need to make it my master drive...can u tell me the jumper settings plz
On the back of the drive you should see 3 groups of 2 pins. One probably already has the plastic jumper on it. They should be marked: m s cs. The m mis the master setting. s is slave & cs is cable select. Place the jumper onto the group of pins marked m & your drive is now set to master. Hope this helps & please remember to rate my answer. Thanks.
2answers
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
3helpful
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
