Seems that either the phone company has cut-off your incoming service (which they do for non-payment), or you have activated a "feature" and need to turn it off.
(phone companies cannot turn off local-outgoing calls for non-payment because that would prevent you from calling 911)
Have you tried calling your landline to see if you hear a message?
A simple call to your Telco Provider would probably resolve this quicker.
In my micromax Q7 mobile all incoming calls are replied with this number is busy. Neither I locked nor barred the calls, knowingly or unknowingly. Please get a solution.
To cancel bared incoming calls on your phone, enter one of the code given below.
##67#, ##21#,##62# or ##61# then okay/send/yes. the phone will be unbarred.
Regards
You need your message centre number for outgoing text messages. You can find the number by going on your networks website or by phoning you networks customer services.
Access your voicemail from your mobile cell phone and record a personalised voicemail greeting.
Now call your number from a landline, and when you hear your voicemail greeting prompt you to leave a message, press the required key sequence to access your voicemail from the landline.
The required sequence is dependent on which network/service provider you are using.
If you let me know which network, i can give you more detailed information.
If its still showins as a busy when the phones plugged in at the NId ( the box outside) then the trouble is showing towards the telco . Call your local provider for repair.
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
