I just want to disconnect it how do I disconnect the alram system
AN EASIER WAY TO DISARM THE ALARM IS TO FIND A SWITCH MOUNTED USUALLY UNDER STEERING COLUMN OR DRIVERS KICK PANEL.
JUST TURN KEY ON
THEN FLIP THE SWITCH.
IF ITS A PUSH BUTTON THEN JUST HOLD DOWN FOR SEVERAL SECONDS AFTER YOU TURN THE KEY ON.
REMOVING THE BRAIN IS EASY.
LAY ON YOUR BACK ON DRIVERS FLOOR AND REMOVE ANY PANELING IF IN THE WAY AND FIND SMALL BLACK BOX ABOUT 4" X 4" X 1.5" MOUNTED WITH ZIP TIES. JUST UNPLUG AND TAPE OFF THE PLUG.
The car alarm on your 2000 Windstar minivan
is wired into your van's battery. When you are making a repair to your
car such as a battery change out your alarm can go off. You can easily
disable the Windstar's car alarm by disconnecting the battery from the
alarm. The battery is connected to the Windstar battery's negative
terminal. Disconnecting the terminal from the battery will disable the
alarm.
