Apple iPod touch Logo
Posted on Jan 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Ipod touch is not connecting to a wifi which has been working up until 2 nights ago, it still says it has medium signal strength, but if i open the itunes store or any other sort of internet connection, it just says either "loading" or "invalid argument" HELP me please!!! :(
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Apr 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
2949
Points
14
Have you had a software upgrade? I had exactly the same problem with a brand new 3rd gen iTouch and it turned out to be a problem with the itouch and the wifi encryption. Mine showed it was connected to the network but wouldn't access anything (invalid argument etc). I tried everything but no joy. Eventually I fixed it by changing the router's encryption from WEP to WPA2-PSK. Fixed it like magic. Where there had been no router or DNA data before, they were suddenly filled in. The key was different but was still on the bottom of the router. I had to re-enter the key on my wireless laptopMy Ipod touch is not connecting to a wifi which - 2_bing.gif but that was a small price.
You can get into the router set-up page through your web browser. I found a guide on You Tube.
Anonymous
Level 2:
New Friend:
  • Expert 81 Answers
  • Posted on Mar 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
81
Questions
0
Helped
12674
Points
139
Do the followings
settings>>wifi>>you will see a blue arrow button next to the connection press that.
if you see the 1st 4 lines full with some number and writings then it is ok or else scroll down and press renew lease or/and try to connect using another network.
let me know the results
i have another one solved like this check
http://www.fixya.com/support/t4259513-itouch_wont_let_me_connect_internet
tip
How do I let my Wireless Be found by my iPod
<p>The iPod Touch comes with Wi-Fi compatibility, so it can connect to any wireless network at home or the public. At the time of publication, the iPod Touch is the only Wi-Fi compatible. Connecting to a network requires a few steps. If your wireless network requires a password, have it on hand before you begin. <br /> <p><br /> <p>1. Touch the "Settings" on your iPod Touch. By default it is located in the upper left corner of the screen, although you may have moved. He is gray with a gear icon. <br /> <p><br /> <p>2. Go to "Wi-Fi and make sure it says" On. "Slide the switch to" Off "to" On "if needed. <br /> <p><br /> <p>3. Wait until your iPod to signal detection network. It may take several seconds. <br /> <p><br /> <p>4. Select the network you want to join the list of available networks. Your iPod can detect more than one signal in your area. <br /> <p><br /> <p>5. Enter the password to the network when prompted, if necessary. The iPod Touch will ask you automatically if a password is required. <br /> <p><br /> <p>6. Tap "Join" and press the Home button to return to the main screen. The Wi-Fi icon in the upper left corner of the screen lights up and shows the signal strength. <br />
on Aug 05, 2011 • Computers & Internet
tip
How to your link to an iPod Touch WiFi
<p>It has all the power of your iPod touch by connecting your device to a WiFi network Connect your iPod Touch WiFi can pull in email, get directions with the Maps application and search the iTunes Store. To connect to a wireless network, obtaining information from the network administrator about the connection, including the name of the signal as it is hidden, the authentication type and password required for use. After obtaining this information, you can configure the WiFi devices are made in minutes. <br /> <p><br /> <p>1. Tap the Settings application on your iPod touch. <br /> <p><br /> <p>2. Tap "Wi-Fi." <br /> <p><br /> <p>3. Tap the slider to the right of the Wi-Fi says "ON". <br /> <p><br /> <p>4. Tap the WiFi signal you want to connect in "Choose a network." If you get an unsecured network, no password and you are automatically connected to the wireless network. If you are prompted for a password, enter it when prompted and tap "Join". You are now connected to the wireless network. <br /> <p><br /> <p>5. Press the "Home" button just below the touchscreen device to return to return to the home screen. <br />
Ipod will not connect to wifi
Connect to WiFi for Your Apple iPod touch b> The iPod touch has the ability to connect to Wi-Fi networks, giving you access to information while on the go. The iPod detects both protected and unprotected networks, and can remember which Wi-Fi networks you have used before, eliminating the need to enter passwords more than once. Your iPod touch should automatically detect wireless networks, but you can also manually connect to a network or switch to a new one.
Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Press the "Home" button to return to the home screen. Tap the Safari Web Browser application or any other application that requires Internet access. A list will automatically open on your screen that names all available networks. Tap the network you wish to use from the list. The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network that is set to not broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal. b> Manually Connect Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Tap a network listed under "Choose a Network..." The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network set not to broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal.
b>
I cannot connect my ipod touch to my router how do i connect it?
First you'll need to turn on your Wi-Fi.
1. Choose (Settings) then (WiFi) then (turn WiFi on)
2. Set iPod touch to ask if you want to join a new network: Choose (WiFi) and turn (Ask to Join Networks) ON or OFF.
Then you'll need to join a WiFi network (your D-Link for instance)
1. Choose (Settings) then (WiFi) then wait until your D-Link shows up in the list of networks.
2. Select your network and if you have a password for your router make sure you type it. (networks that require a password have a lock icon next to it) then tap (join)
Once you join a WiFi network manually, iPod touch will automatically connect to it whenever the network is in range. If more than one previously used network is in range, iPod touch joins the one last used.
When iPod touch is connected to a WiFi network, the WiFi icon in the status bar at the top of the screen shows the connection strength. The more bars you see, the stronger the connection.
Good Luck
Ipod touch won't connect to my wifi
things to check again:
1- if DHCP enabled 2- which type of security encryption is used, if WEP change to WPA, use numbers instead of mixed characters for wifi password 3- if MAC filtering is on on the router 4- if signal strength is good
hope that any one of the above solves your problem
Just bought one from my freind ,how do i get the internet working on it
iPod touch gets its internet from WiFi signal that it captures. If you don't have WiFi around you, you will not be able to connect to the internet.
To see if there are available WiFi connections around you, here's what you gotta do:
>on your iPod touch screen, go to Settings
>once the Settings window opens, you'll see Wi-Fi next to Airplane Mode (from the top). If your current not connected to any WiFi signal, it should say not connected beside it.
>tap on Wi-Fi and choose from the available networks on the list, but make sure that Wi-Fi is turned ON, first. If in case there's no WiFi signal around you, you still won't be able to browse the web.
>tap on any network from the list. often times, WiFi signals are secured, which means you should know the password to be able to connect, otherwise, you'll still get nothing.
you'll know that you're already connected when there's a check symbol on the left side of the network that you've just selected, and also, the WiFi symbol appears beside your carrier name.
Once you're connected, just exit the Settings window and go to Safari to browse the web.
For more iPod touch / iPhone tips, click here.
2answers
Ipod touch 8gb is connected to wifi but not internet
if the internet connection isnt strong it will not work for me so get closer.
No wi fi for itouch
Usually, all iPods have a WiFi chip imbedded in the device so you have to pay nothing except for your currently active Wireless internet connection. Try checking your modem and making sure it's working for starters. If it is, then go on the iPod and go to settings, then internet connections. Select a valid internet connection and it should automatically connect, given a good signal strength.
If this helped/didn't help, let me know.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
