Lands Phones Logo
Posted on Jan 16, 2010
How do I set up my blue tooth with my LG cell phone? The blue tooth was given to me without instructions....used
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
752
Points
9
Can you go to tools and then connection then it should say bluetooth link click on it and then click on handsfree maybe?
1helpful
2answers
I want to transfer picutes from my phone to PC
Welcome, Thank You for giving fixya.com the opportunity to HELP!
Your issue:
I want to transfer my pictures? from my phone to my pc.
Solution:
Your case will need the following kit witch you can purchase from HERE
If you already have the USB transfer cable all you need to do then is download the software from that website, install it on your computer, this will sync all your photos to your pc without a hassle.
We only give you the facts that you need in order to get the solution done. You will need to purchase if you have not already the transfer cable and kit from the source given.
Your ratings are important to us. Please be considerate when passing through Fixya.com to leave feedback so we know how we are assisting our askers.
Best Regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
How can i get music on my phone without a sd card
If your phone comes with a usb cord,you can download music from a computer to your phone. If it has a blue-tooth, you can transfer music to it through blue-tooth device.
1helpful
How do I pair bluetooth from one phone to a new phone? Removing bluethooth from my old phone to another phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
1helpful
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
Take care.
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
Take care.
1helpful
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Can't set up blue tooth
Strangely enough I went to the website where I purchased the blue tooth. It recommended holding down the button for 8 seconds as opposed to the 3 or 4 listed in the manufacturer's instructions. When I did this it found my phone. The pairing worked fine and now so does the blue tooth.
Lg rumour and blue tooth
call the store adn they will tell you what to do or you can do it the old fashoned way and read the manual lol
LG KG290 Dial up problem
I have verified that your phone supports DUN Bluetooth profile so you should be able to use it as intended.
You need to verify though that your dongle supports DUN service profile. If it does, you may follow the instruction below for step-by-step guide:
http://www.pocketpccentral.net/help/wm_bluetooth_modem.htm
Need instructions to set up blue tooth in my phone
Yes, it would help if you gave the model number. However, if you do a google search for LG Rumor user manual, you should be able to find a download.
Jun 16, 2008 • Cell Phones
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
