Trying to connect hp laserjet 4p to comp old printer. been given this old printer and would like to try before perhaps getting new one am new to doing anthing on comp and would be grateful for any help
Re: want to connect hp laserjet4p printer to comp but
Hello sir; Don't worry! if your computer with wizard software, that will be easy for you to connect, click on start on your computer then go to setting click on printer & fax select adding printer, then follow the instruction to finish the installation.
In general, yes. Some model-specific features won't work with other models, of course. For example the 4P does PostScript while the 4 does not. But as long as the customer confines himself to basic printing, the 4L driver should work properly with any of the 4-series printers.
If you are change the toner while not fix this problem so,You must be change laser unite.Or not you change your old toner unite/cartridge and buy new one.Hp part no 98A.
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it. Good Luck the HP Laserjet 4p is a great printer.
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
