Exercise & Fitness Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Efx 556 ERROR EE32 WHAT DOES THIS MEAN? - Precor Exercise & Fitness
John Mazmanian
Level 3:
President:
  • Precor Master 832 Answers
  • Posted on Apr 09, 2010
John Mazmanian
Precor Master
Level 3:
President:
Answers
832
Questions
0
Helped
628629
Points
2056
Lost communication between the upper and lower board You have 2 interconnect wires and mid point connector . You may have a loose connection at any of of the 4 connection point or a bad wires. Go to gymparts.com on left hand side you will see diagnostics and repair click on it scroll down until you Precor 556 look for you serial# and click to PDF and it should give you the necessary info to hunt your problem down
Precor EFX 556 cross trainer slow startup
Il existe deux raisons pour lesquelles votre v?lo elliptique Precor EFX 556 d?marre lentement. Tout d'abord, un probl?me ?lectrique, tel qu'un cordon d'alimentation mal branch? ou endommag?, ou m?me une prise d?fectueuse, pourrait survivre. Un condensateur d?fectueux ? l'int?rieur de l'appareil, qui peut causer des retards au moment de la mise sous tension, est une autre explication. Pour r?soudre ces probl?mes, commencez par v?rifier les connexions ?lectriques. Envisagez d'appeler un technicien qualifi? pour diagnostiquer et r?soudre un probl?me ?lectrique ou ?lectronique si le probl?me persiste.
Error 5 stuck key
Precor Error 05, Key Depressed at Power Up Probable Cause: 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Loud groan from rear of machine
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Typically this is caused by a bad pillow block bearing. I would suggest trying to pin point the sound a bit better, but this is common of the pillow block bearings.
Precor Parts for EFX 554i 556 556i Ellipticals SPORTSMITH net
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
2helpful
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
