To change the Voicemail centre number go to:
Menu/Tools/Calls/Divert calls/Voice calls (select the option you need)/Activate, and here's your number. Change it to the number specified by your service provider.
To change the Voicemail answer message call the centre number direct and take it from there. Follow directions, the first thing the automated voice will ask is your mobile number.
It is usually under message menu. try under setting of this menu. Alternatively you can use one more method that will sound funny but works. Press and hold the No. 1 key and see which number it is dialing. If the voicemail is already set it will be shown to you, edit this from the phonebook to your desired number. If the Voicemail has not already been set you will be prompted to enter you the voicemail number. Fill in the desired number there.
i want to change my voicemail nymber.please tell me how to do it.
