Sewing Machines Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need owner's manual for Bernina Patchwork 140
Need owner's manuals for Bernina Patchwork 140 sewing machine
Anonymous
Level 2:
New Friend:
  • Expert 108 Answers
  • Posted on Feb 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
108
Questions
0
Helped
41812
Points
171
Try at www.ifixmachines.com
Dose the bernina 140 do embroidery
The Bernina Patchwork 140 does not do embroidery from a file (either built-in or external). You can do some free-hand embroidery by lowering the feed dogs. Depress the feed dog position button on the right hand side of the machine. It's below the balance dial and between the foot control socket and the power cord socket.
I hope this helps. ManualsLib has the manual for the Bernina 140; it's a shared manual with the Activa 130 and 131.
2answers
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: https://www.manualslib.com/manual/1002243/Bernina-Activa-131.html . The Bernina 135 has the needle stop up/down button. See https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-135 . The manual for this model is https://www.bernina.com/getdoc/90f75840-2b12-4f46-88f2-76f09e35d8d4/030529-52-04_0303_a135-a145_EN .
I hope this helps.
What is the fair market value for a Bernina patchwork 140 machine
Difficult to say. Valuations vary depending on the condition, the accessories included, and where it is located. You can check eBay or some other sites to see how much similar machines are selling.
What needle do i i need for a bernina patchwork 140 ?
The 130/705H needle system is standard across most domestic sewing machines so should be what your Bernina takes too.
2answers
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
1helpful
I can''t remember the steps to make a button hole using my Bernina patchwork 140. I have the # 3 foot. What button do I push to turn the corner manually?
you can download a manual for the Activa 145 here, buttonholing steps would probably be very similar for your model
http://www.bernina.com.au/webautor-data/888/0305295204_0303_a135-a145_EN.pdf
It says you sew one bar, then press the reverse button and the automatic function then sews the bar tacs, other side, bar tack and finishes.
Bernina Patchwork 140 handwheel is getting stiff to turn
A stiff handwheel can be a simple as a thread stuck in the raceway or as severe as a failed uppershaft bushing.
Using your instruction manual, perform the basic maintenance and see if that helps. If not, take it to a repair person for evaluation.
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
