When I power up the unit everything seems to operate. When i try to use the humidity button the down button beeps when pressed but the display shows on. The up button doesn't beep when pressed and the display just shows on
The control board is a very simple design and it is to signal and switch options like fan speed, power on/off, humidity up/down and sets the on/off run time. Like above the board does collect dust,but the true problem runs deeper.
My unit was stuck in run mode with the fan speed, humidity and run timmer non functioning. the unit worked and the power switch turned it on and off. The display said ON
I removed the front cover (two screws) and slight pressure on the side of the cover to remove it. This exposes the control board. The control board can be removed by removing the 6 screws on the board. the cable can then be removed by pulling out the multi-pin ribbon cable.
I diagnosed that only two of the 5 push button switched were functioning. There was also dust and mold on the board. This board is poorly protected from the moist air entering the unit and the constand moisture causes corrosion on the board, the switched seem to be the weak link.
By using a multi meter I noted that only the power switch and the humidity down button were making contact when pressed. Now it all came together. I could turn it on and off. and if you press the humidity down button to the lowers setting (ON) means run all the time.
I used a elecronic contact cleaner and sprayed it into each of the switches. I wiggled it around and blew it out with canned air. It took a few wiggles and blasts but all switched then made contact. I the board back on and tested all functions and it was like new. The contact cleaner should keep it protected for a while. The non functioning of the switches works both ways. They can stick on also. This would explain most of the other control problems. These switched are common and can be picked up at Radio Shack. On a do-it-yourself bananna scale it was a 2 for me, but I had the tools and the spray. I am not sure what sears gets for the PC control board,but this is the issue and if they were to address this the unit complaints would drop greatly.
Fixed the problem. Removed front panel ( 2 screws), unscrewed and removed circut board, 5 little screws. Removed all dust from inside panel conatcts and board. Reassembled , also cleaned filter to improve air flow. working fine - power comtrols and humidity controls work. easy to do.
Power control button and humidity buttone does not respond. Machibe is stuck in ON mode. Must plug or unplug tp operate. 2years old
I have the exact same problem. My setting was at 55%. I noticed the fan stopped working so i replaced that. When i turned the unit back on i saw it was not at 55% so i tried to push the up button nothing happened. I then pushed the down button and it did choose the humidity levels untill it got to ON.
Now i get no response at all from the up button and the down just beeps when pressed
