Linksys WRT160N Wireless Router  Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not allow me to connect using an ipod touch.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
859
Points
I'm also using a WRT160n (v1) with WPA2. Problem wouldn't go away until I tried a solution I saw on Amazon.com related to the 160. Sounds strange, but it worked.
1. Disable security on the router.
2. Select network from Wifi list on Ipod (this connects the Ipod every time for me)
3. Enable security on the router.
4. Type in password on Ipod, it will force you to reconnect to network after it sees password on router is enabled. (I also used upper case letters this last time, which someone might want to check it's not as simple as Apple forgetting to filter hex characters to upper case....)
Voila, I am connected.
Hope this helps
Anonymous
Level 1:
New Friend:
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
859
Points
I have new Linksys WRT160N and new Ipod Touch. Wouldn't at first connect but when I upgraded firrmware to router it fixed the problem. Using WPA2 and version 3 of hardware.
Anthony Miller
Level 2:
Scholar:
  • Expert 141 Answers
  • Posted on Jan 01, 2010
Anthony Miller
Expert
Level 2:
Scholar:
Answers
141
Questions
0
Helped
38826
Points
303
I believe the iPod touch communicates using Wireless G. The WRT160N can communicate with B, G and N devices. However, you may have to change your wireless settings on the WRT160N to allow wireless G devices. This will slow down the overall speed of your wireless network though. Another issue could be your wireless security. The iPod touch works with WEP and WPA but I am not sure if it works with WPA2 security. You may also check those settings. These two areas are normally the two problem areas if you are seeing the router that is..
Carl Navarro
Level 3:
  • Master 2,460 Answers
Carl Navarro
Master
Level 3:
Answers
2460
Questions
Helped
1155926
Points
7314
My IPaq wireless has an icon that lets me log into other networks by just selecting them and putting in the password or no password if it's an open network.
I Googled the Ipod touch instructions and found a MAC blogger with the specific instructions here http://mac.blorge.com/2008/07/14/wi-fi-setup-how-do-i-access-the-internet-with-my-ipod-touch/
If you can't login because you don't see the router, try logging into the router from a computer connected to it and make sure the wireless is turned on and broadcasting an SSID. If you have a WEP password set, you will be able to read it under the Wireless Basic Wireless Settings tab. If you need specific help with the WRT, you may visit the Linksys site. Here's a link to connecting your wireless device to a Linksys product http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=20947
or, here's a manual where you can start at page 13 http://downloads.linksysbycisco.com/downloads/userguide/WRT160N_V10_UG_A-WEB,0.pdf
Carl
4answers
How to transfer ebooks from ipod touch to window 8 computer ?
iPubsoft iPad iPhone iPod to Computer Transfer can help you to copy ipod ebooks to computer. This article shows an efficient way to transfer books from iPod/Touch/Shuffle/Nano/Classic to PC. If you like reading iPod eBooks on computer, this tutorial is just rightly written for you. iPubsoft iPad iPhone iPod to Computer Transfer
tip
How do I Enable Disk Management for the iPod Touch
<p>If you want to use Disk Management to partition and format the iPod Touch, you must enable disk use on your iPod. By default, Apple iPod products configured to work with Apple's iTunes and not as portable drives on your computer. You can use iTunes on your hard drive mode to allow your iPod, allowing the computer to deal with and recognize the iPod as a portable unit. <br /> <p>1. Connect your iPod to your computer using the USB cable for iPod. <br /> <p><br /> <p>2. Launch iTunes. Select your iPod from the "Devices" from the iTunes browser. <br /> <p><br /> <p>3. Click on the "Summary" tab in the main iTunes window to change the settings for your iPod. <br /> <p><br /> <p>4. Go to the bottom of the Settings window and check the "Enable Disk Use". The computer recognizes the iPod Touch as a portable disk. <br /> <p><br /> <p>5. Quit iTunes. Run the Disk Management and check the disk devices connected to ensure that your iPod is displayed as a portable unit. <br />
on Aug 08, 2011 • Apple iPod touch
tip
How to connect to the iTunes Store, an iPod Touch with WiFi
<p>The iPod Touch iTunes Store requires an active Wi-Fi or cellular connection service to work properly. Unlike the iPhone, Apple iPod Touch has no ability to mobile data services. If you connect to the iTunes Store on your iPod Touch, you must first connect to a wireless Internet network. This allows you to enter the iTunes Store on iPod Touch and make purchases directly on your handheld. <br /> <p><br /> <p>1. Click the "Settings" button on your home screen. <br /> <p><br /> <p>2. Select "Wi-Fi." The Wi-Fi page loads. Slide the switch to "On" position. A list of taxes Wi-Fi networks <br /> <p><br /> <p>3. Select the Wi-Fi is connecting. If you are prompted for the network password, enter the password and click "Join." The iPod Touch connects to Wi-Fi network you selected. <br /> <p><br /> <p>4. Tap "Settings" back arrow on the toolbar at the top of the screen to return to the main Settings menu. <br /> <p><br /> <p>5. 'Store' select the tab. The page is loading Store. Touch the "Sign In" button. <br /> <p><br /> <p>6. Select "Use existing Apple ID" from the options pop-up windows that appear. <br /> <p><br /> <p>7. Enter your email address Apple ID and password in the "Email" and "Password" field of the prompt signal. <br /> <p><br /> <p>8. Click the "OK" in demand for the iPod Touch connected to your iTunes Store account<br />
on Aug 05, 2011 • Apple iPod touch
On my ipod touch, it says that ipod is diasabled and connect to itunes. when i connect my ipod touch to itunes, itunes say that itunes cannot connect to ipod touch because it is locked with a passcode. i...
this is the solution for this kind of issue. please try it. It might work on your ipod touch.
please click here
hope this helps . . . please don't forget to vote for this solution if this works for you :) . . . thanks
Please HELPPP MMEE with my ipod touch PLEASEEE
Here I have the easiest solution for you but this will cause a permanent loose of all the data you have on your ipod.
If it is okay with you then follow my instructions here
tip
How do I Transfer Applications From an iPod to iPod
<p>Apple iPod Touch media player allows applications of the iTunes App Store and download applications on the device. If you prefer, you can synchronize these applications with the application iTunes media management, and here, shopping for another iPod touch in a few easy steps. <br /> <p><br /> <p>1. Connect iPod touch to your computer through the USB cable that came with the device. Double-click the iTunes application icon to start the program. <br /> <p><br /> <p>2. Click the iPod touch, listed under the "Devices" section and select "Transfer Purchases" option from the context menu. Allow several minutes for all applications downloaded to the iPod touch through the computer. <br /> <p><br /> <p>3. Click the 'Eject' button next to the iPod touch under the "Devices" section and turn off the iPod touch to your computer. <br /> <p><br /> <p>4. Connect the iPod touch in the second computer through the USB cable. Click new iPod contact listed under the "Devices" section. <br /> <p><br /> <p>5. Click on "Applications" tab and place a checkmark next to "Sync Apps" option. Click the "Apply" to apply the changes and synchronize applications to the iPod touch second. Wait a few minutes to sync process is complete. Once it does, and the computer a message, click the "Eject" and remove the iPod. <br />
tip
How to put the Internet to an iPod
<p>Apple's iPod device only with Internet capabilities, the iPod Touch. Other versions of the device can only synchronize with a computer full of music and video. The iPod Touch, however, can connect to wireless Internet networks, where available. Bringing the Internet to your iPod Touch, you need Wi-Fi settings to activate the device. Once you allow them, the iPod Touch Wi-Fi settings will be available networks, you can connect to a tap of the finger to detect. <br /> <p><br /> <p>1. Click the Settings icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Click Wi-Fi <br /> <p><br /> <p>3. Click "On". <br /> <p><br /> <p>4. Click a wireless network in the list that appears to connect. <br />
on Aug 05, 2011 • Computers & Internet
2helpful
How Do I Unlock My Ipod Touch When It Says Its Disabled?
"1. Connect the iPod Touch
2. Press and hold sleep+home until the device reboots.
3. Keep holding until that "please connect me to iTunes"-screen appears
4. iTunes says something about having detected a touch in recovery mode. Allow it to do its thing.
If you get the -18 error, proceed:
5. Disconnect the iPod Touch
6. Close iTunes
7. Reconnect the iPod Touch
8. iTunes launches and shows message as in step 4, but this time, the recovery will work."
Hope this helps!
Ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
tip
How to change WiFi security on my iPod Touch
<p>Are equipped with Wi-Fi connectivity that allows the device using wireless Internet networks. The iPod Touch can connect to open and secure Wi-Fi signals, and remember the details of the networks that had already turned on. If you enter the wrong password when connecting to a secure network, the iPod Touch still remember the password and try to use whenever it is within reach. The password must be manually placed back into the iPod settings to connect properly. <br /> <p> <br /> <p>1. Start the Settings application on the iPod Touch, tap the home screen. <br /> <p><br /> <p>2. Open the "Wi-Fi" page. The list of upcoming Wi-Fi will be displayed. <br /> <p><br /> <p>3. Touch the small blue arrow to the right of the Wi-Fi network that you want to change the "Select Network" list. A detail of the network is displayed. <br /> <p><br /> <p>4. Select "Forget this Network" button at the top of the screen. This removes all previously entered security information stored on the iPod Touch. <br /> <p><br /> <p>5. Tap again to the network in the "Select Network" list and enter the password security options on the pop-up box. Press the "Register" button to connect to Wi-Fi network with the security detail changed. <br />
on Jul 21, 2011 • Computers & Internet
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
