Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pour o matic pours water through filter even if un plugged is it just full and needs to get rid of the h2o
Anonymous
Level 2:
  • Expert 124 Answers
  • Posted on Dec 31, 2009
Anonymous
Expert
Level 2:
Answers
124
Questions
0
Helped
66633
Points
174
YES.
The unit has a tank used to heat the water for brewing.
When you add more water, the unit starts the brew cycle.
1helpful
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
1helpful
My bunn pour o matic coffee brewer will not brew. all burners get hot but it will not pump the water out into the filter basket. What could be the cause?
Hello Doug,
This is a clogging issue. Meaning it needs to be cleaned. So what I want you to do, if first read this manual that I am sending you via a e-mail link. Just copy and paste link in browser; I am positive it is just clogged. In the manual it will show you some tips on how to unclog it with tooth pick etc... then you want to flush whole system with water and vinegar. Here is the link to put in browser. http://www.bunn.com/pdfs/commercial/manuals/10424.0000.pdf
Mike
My pour-omatic steams up overnight then will not brew full pot
Check the thermostat on the machine, make sure pot is full before brewing. The water in the tank just heats up it is loosing most of it, make sure lid is on pour in screen.
Where do I pour more water into it? It automatically shuts off when it runs out of water, I purchased it from a friend who did not have an owner's manual so I don't know where to add more water so it...
You don't pour water in that. It makes its own water. LOL
It shuts off when it gets full of water. I am not familiar with this dehumidifier but I know it holds 4 pints then the float comes up and kills the power. Take the cover off and I am sure you will find a tub full of H2O.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Pour in one full caraffe of cold water when the machine is not switched and cold.the water immediately runs out. The switch on and it keeps on boiling. Should it not switch of when temp. is reached. Model...
www.bunnomatic.com/pdfs/commercial/manuals/33545.0000. From what I understand the swithc is to stay on at all times unless you are going to be away for awhile. The water you are pouring in will be the reseve for the next pot. I'm not sure if it should be boiling but check the filling instructions from above . I had no idea how to fill as mine was bought used. Good Luck! God bless!
How to use coffee maker
This type of coffee maker is made to keep hot water always ready to make another pot.
Pour water in ( at least 4 cups)then turn it on with the pot installed to catch the water. It takes a few minutes to get it hot . You might hear it heating. I can with mine.OK after the heating sound goes away put some coffee in the filter and in stall the filter.Now, fill the pot again (at least 4 cups) and pour the water in and put the pot ready to catch the coffee.It makes the coffee fast because it already heated the water from the first time you poured it in.When finished with the coffee just turn off the burner only.These types are made to stay on 24 hours a day.
I just turn mine off and let it heat up the water in the morning.
3helpful
Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
BUNN VPR
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
