After hitting the eject button... light comes on like its ejecting, makes some sounds, then light blinks again like i loaded a new game in, but it never ejected the original game. Game loads in console properly, just wont eject.
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
Try all of these steps:
1. Turn the Wii off and on again after about 20 seconds. Press the eject button again. If no help:
2. Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. If no help:
3. Hold down the eject button for 5 to 10 seconds. Still not:
4. Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. if no help:
5. See if power light was coming on and do the AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for 5-10 seconds
Finally:
Call Nintendo 1-800-255-3700 and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Good Luck
Hmmmm, try reseting the wii or synching it. The sync button is under a removeable piece of plastic on the console??? it will show you in the manual.
Srry, im no an expert if that doesnt work.
Try tilting the wii at several angles. The disc may come out. If not try hitting the eject button at several angles.
If all the above fails, this(although risky) may work.
1. find another disk.
2. slide into slot, just enough to get under the cd(NOT ALL THE WAY IN)
3. lift or puch down on the disk depending on the side the new disk is on
4. hit eject while lifting or puching.
5. If this does not work the system may need to be sent out
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!! I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly. 2.Then switch on the WII (As i said early the WII won't eject the CD. 3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B). (A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(. (A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D. (B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
we got it to work eventually by using a pin (ie a dressmakers pin). We realised the eject button wasn't clicking when pushed down, so was physically stuck, so used pin to pop the left hand side of the eject button out/up. Works a treat now.
I managed to eject a WII disc out manually very easily: - Disconnect the drive - You see the white plastic mechanism on your right side and the wheel connected to the motor - turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left. You will see the disc coming out while you are turning the wheel.
