Computers & Internet Logo
Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have Windows XP. When trying to open Disney Magic Artist Classic Parents' Help File, message appears: "Can not open Word for Windows 6.0 files". says this program is compatible with Windows XP; Have downloaded and can open the program but need instruction for learning how functions work, in order to help my kids.
Anonymous
Level 3:
  • Master 691 Answers
  • Posted on Dec 20, 2009
Anonymous
Master
Level 3:
Answers
691
Questions
0
Helped
156694
Points
1852
Help files do not generally need MS Word, sounds to me someone has changed the file type open program options
Im tring to install disneys magic artist studio cd rom windows 95/98 but it wont work on my macbook pro
thats because its a windows disk. let alone that its from windows 95/98 which is COMPLETELY incompatable with a macbook pro. unless you actually know what youre doing windows .exe files do not run on mac os
How to register .ocx files?
To register an ocx file simply follow the simple steps below.
1.Locate the file using windows explorer or My Computer. Alternatively search for the filename.
2.Hold down the shift key and right click on the file. Then click 'Open With...' from the menu.
3.An 'Open With' dialog box should appear. Click the button 'Other...'.
4.Navigate to your windows\system32 directory and select the file 'RegSvr32.exe'. Do a file search for it if you have trouble locating the exact folder. On Windows 2000 it is typically located in c:\WINNT\System32. Click Open to select the file. Then click OK on the 'Open With' dialog.
5.You should see a message indicating the file was successfully registered. If you see an error message, try restarting your computer and going through the above process again.
Thanks for visit us
3helpful
Every time I try to boot up print artist platinum edition it says Print Artist Platinum has encountered a problem and needs to close. What do I need to do to fix the problem?
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
1helpful
I need the drivers for my veo web cam
this program should help you download,instal then scan and update you drivers is free from here www.radarsync.com
2answers
Dell Dimension 4700 can not install Windows XP
It looks as though when deleting the OS you might have gotten jacked and the rom drivers were lost.
I am trying to download images off my computer which is a toshiba laptop on to sierra print artist 4.0 gold card making programme can you help me
first off...you have to import them....and then, only files that Print Artist will accept....
open print artist...and in the FILE menu...click IMPORT, and point to the file you wish to send to PA. Then, make sure PA will accept this type of file...and click OK...'
You have to Name the file also, I believe.
Good Luck
Top Disney Computers & Internet Experts
john h
August Brown
August Brown
Are you a Disney Computer and Internet Expert? Answer questions, earn points and help others
